Dpkg: error processing archive
Hi, I’m using CUDA11.8 and cuDNN 8.6 for tensorflow.
Ubuntu 20.04 and nvidia-driver 520.56.06
everythig was fine.
But when i try to install another packages, error occures.
root@c01fec5b273e:/# sudo apt-get install ros-noetic-rqt
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 cuda-drivers-545 : Depends: nvidia-compute-utils-545 (>= 545.23.08) but it is not going to be installed
                    Depends: nvidia-utils-545 (>= 545.23.08) but it is not going to be installed
 nvidia-driver-545 : Depends: nvidia-compute-utils-545 (= 545.23.08-0ubuntu1) but it is not going to be installed
                     Depends: nvidia-utils-545 (= 545.23.08-0ubuntu1) but it is not going to be installed
                     Recommends: libnvidia-compute-545:i386 (= 545.23.08-0ubuntu1)
                     Recommends: libnvidia-decode-545:i386 (= 545.23.08-0ubuntu1)
                     Recommends: libnvidia-encode-545:i386 (= 545.23.08-0ubuntu1)
                     Recommends: libnvidia-fbc1-545:i386 (= 545.23.08-0ubuntu1)
                     Recommends: libnvidia-gl-545:i386 (= 545.23.08-0ubuntu1)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
so i type the apt --fix-broken install
Preparing to unpack .../nvidia-compute-utils-545_545.23.08-0ubuntu1_amd64.deb ...
Unpacking nvidia-compute-utils-545 (545.23.08-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-compute-utils-545_545.23.08-0ubuntu1_amd64.deb (--unpack):
 unable to make backup link of './usr/bin/nvidia-cuda-mps-control' before installing new version: Invalid cross-device link
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../nvidia-utils-545_545.23.08-0ubuntu1_amd64.deb ...
Unpacking nvidia-utils-545 (545.23.08-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-utils-545_545.23.08-0ubuntu1_amd64.deb (--unpack):
 unable to make backup link of './usr/bin/nvidia-debugdump' before installing new version: Invalid cross-device link
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I’m stuck in the loop.
In terminal, nvidia-smi and nvcc -V are works well.
| NVIDIA-SMI 520.56.06    Driver Version: 520.56.06    CUDA Version: 11.8     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0  On |                  N/A |
| N/A   50C    P8    21W /  N/A |    565MiB /  8192MiB |      1%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
Is there are any problem here?
thanks
