I have followed the guide of installing cuDNN on linux
I’ve downloads cuDNN-version 8.3.1.22 ubuntu 16.04 for cuda 10.2, file name is [cudnn-local-repo-ubuntu1604-8.3.1.22_1.0-1_amd64.deb].
when it came to 2.3.2 - install the runtime library, i try
$ sudo apt-get install libcudnn8=8.3.1.22-1+cuda10.2
but
E: Version ‘8.3.1.22-1+cuda10.2’ for ‘libcudnn8’ was not found show up, i can’t figure out what is wrong. can anybody help me.
Are you still facing this issue.
Please make sure you followed step 2, 3, 4 before that.
Thank you.
Hi I am facing a similiar issue with a different version mix:
sudo apt-get install libcudnn8=8.4.0.27-1+cuda11.1
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Version ‘8.4.0.27-1+cuda11.1’ for ‘libcudnn8’ was not found
and I did follow steps 2, 3 and 4.
Same issue.
$ sudo apt-get install libcudnn8=8.4.0.27-1+cuda11.2
Building dependency tree… Done
E: Unable to locate package libcudnn8
One of our testers was able to reproduce the same error if they skipped step 4 in the instructions:
Please do this command:
sudo apt-get update
Before the install, and let us know if it works.
Same here.
$ sudo apt-get install libcudnn8=8.4.0.27-1+cuda11.4
E: Version ‘8.4.0.27-1+cuda11.4’ for ‘libcudnn8’ was not found
*I already did
$ sudo apt-get update
, it just wont work.
In the end I went to the cudnn archive and download older version
https://developer.nvidia.com/rdp/cudnn-archive
Same problem, version 8.3.2.44 is working … 8.4.0.27-1 is not
This might do the job.
After step -
sudo apt-key add /var/cudnn-local-repo-*/7fa2af80.pub
You will have the directory /var/cudnn-local-repo-ubuntu2004-8.4.0.27 (with your ubuntu version and cudnn downloaded)
Inside this directory, you will be having three .deb files.
just do for all the deb files-
sudo gdebi xxx.deb
which will install cudnn. ;)
@dishant.daredevil yours is the working solution for me for installing on ubuntu20 .
just did
sudo gdebi XX.deb
by going into dir /var/cudnn-local-repo…
Hello
Try running the command as
i.e., without writing ‘=8.x.x.x-1+cudaX.Y’ this part.
For 8.4.0.27, the cuda version expected is 11.6 even for my system with cuda 11.5
Therefore run the install command with cuda11.6 at the end
You need to update the public key for the repo and apt-update again.
I wonder if there isn’t a existing verson of cudnn for CUDA11.7
If you browse to the distro (Index of /compute/cuda/repos/ubuntu2004/x86_64 in my case), you can see what it is looking for in the list of links. For instance:
libcudnn8_8.4.1.50-1+cuda11.6_amd64.deb
libcudnn8_8.4.0.27-1+cuda11.6_amd64.deb
Hope this helps someone
I was trying to install cudnn 8.4.1.50 on Ubutu20.04 with Cuda Toolkit 11.7, but there does not seem to be a version for 11.7 yet.
>sudo apt-get install libcudnn8=8.4.1.50-1+cuda11.7
Reading package lists... Done
Reading state information... Done
E: Version '8.4.1.50-1+cuda11.7' for 'libcudnn8' was not found
though, as previous suggested, the following got the version for 11.6 for me
The following NEW packages will be installed:
libcudnn8
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 420 MB of archives.
After this operation, 1,198 MB of additional disk space will be used.
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 libcudnn8 8.4.1.50-1+cuda11.6 [420 MB]
Fetched 420 MB in 5s (89.7 MB/s)
Selecting previously unselected package libcudnn8.
(Reading database ... 231586 files and directories currently installed.)
Preparing to unpack .../libcudnn8_8.4.1.50-1+cuda11.6_amd64.deb ...
Unpacking libcudnn8 (8.4.1.50-1+cuda11.6) ...
Setting up libcudnn8 (8.4.1.50-1+cuda11.6) ...
Thanks a lot, it worked perfectly for me!
Thank you it worked for me :)
Even I had similar issues.
Checked naming conventions of deb files in /var/cudnn-local-xx and used the same in apt-get install,
sudo apt-get install libcudnn8=8.6.0.163-1+cuda11.8
it worked !!
That’s the deal. It’s common mistake to confuse the versions of both the cuda version installed on computer and the libcudnn name (which refers to the most recent relead of cuda).
One should look into var/cudnn-local-xx folder for the names of the deb to use.
