Download cuDNN issues
On Ubuntu 20.4, I am trying to download cuDNN.
$ nvidia-smi
Mon Oct 26 00:03:40 2020
| NVIDIA-SMI 455.23.05 Driver Version: 455.23.05 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce RTX 208… On | 00000000:0B:00.0 On | N/A |
| 18% 36C P8 1W / 250W | 655MiB / 11011MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3607 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 7468 G /usr/lib/xorg/Xorg 366MiB |
| 0 N/A N/A 7670 G /usr/bin/gnome-shell 58MiB |
| 0 N/A N/A 278130 C …ffice/program/soffice.bin 157MiB |
| 0 N/A N/A 669669 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 671089 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 674203 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 678057 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 699035 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 719914 G /usr/lib/firefox/firefox 3MiB |
First, CUDA is the newest version 11.1 , which does not have a corresponding cuDNN yet according to https://developer.nvidia.com/rdp/cudnn-archive#a-collapse803-110. So, I downloaded cudnn- 11.0 -linux-x64-v8.0.3.33.tgz. Would this be OK, or I need to install CUDA 11.0 instead? Second, after I extracted cudnn-11.0-linux-x64-v8.0.3.33.tgz,
I did:
$ sudo cp cuda/include/cudnn*.h /usr/local/cuda/include
sudo cp cuda/lib64/libcudnn* /usr/local/cuda/lib64
$ sudo chmod a+r /usr/local/cuda/include/cudnn*.h /usr/local/cuda/lib64/libcudnn*
Adding this line at the end of ~/.bashrc:
export CUDA_HOME=/usr/local/cuda
$ source ~/.bashrc
/etc/ld.so.conf.d/999_cuda-11-1.conf
was edited from:
/usr/local/cuda-11.1/targets/x86_64-linux/lib
to
/usr/local/cuda/extras/CUPTI/lib64
$ sudo ldconfig
However, ater this, when I ran
$ cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2
it produced no output. I do have:
/usr/local/cuda/include$ ls -l
total 81
-rw-r--r-- 1 root root 29025 Oct 24 20:39 cudnn_adv_infer.h
-rw-r--r-- 1 root root 27700 Oct 24 20:39 cudnn_adv_train.h
-rw-r--r-- 1 root root 12527 Oct 24 20:39 cudnn_backend.h
-rw-r--r-- 1 root root 29011 Oct 24 20:39 cudnn_cnn_infer.h
-rw-r--r-- 1 root root 10177 Oct 24 20:39 cudnn_cnn_train.h
-rw-r--r-- 1 root root  2968 Oct 24 20:39 cudnn.h
-rw-r--r-- 1 root root 48825 Oct 24 20:39 cudnn_ops_infer.h
-rw-r--r-- 1 root root 25733 Oct 24 20:39 cudnn_ops_train.h
-rw-r--r-- 1 root root  2785 Oct 24 20:39 cudnn_version.h
Have I installed cuDNN cuccessfully? Thank you!
Hi @ml21,
Request you to follow the below link for cuDNN installation.
You can also verify your current installation with the below link
