Cudnn v8 download error
For ubuntu 20.04 the command
sudo apt-get install libcudnn-samples=8.3.2.44_1+cuda11.5
gives
E: Unable to locate package libcudnn-samples
How can I determine the correct download name ? According to the documentation, this format is correct.
Could you please try as step 7 in the following installation guide.
Command should be sudo apt-get install libcudnn8-samples=8.x.x.x-1+cudaX.Y.
Please make sure you run before commands as well.
Thank you.
