On Ubuntu 20.4, I am trying to download cuDNN.
$ nvidia-smi
Sat Oct 24 10:16:44 2020
| NVIDIA-SMI 455.23.05 Driver Version: 455.23.05 **CUDA Version: 11.1** |
| | | MIG M. |
| 0 GeForce RTX 208... On | 00000000:0B:00.0 On | N/A |
| 18% 36C P8 1W / 250W | 241MiB / 11011MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3607 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 7468 G /usr/lib/xorg/Xorg 129MiB |
| 0 N/A N/A 7670 G /usr/bin/gnome-shell 41MiB |
| 0 N/A N/A 9445 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 9651 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 9733 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 12954 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 13171 G /usr/lib/firefox/firefox 3MiB |
| 0 N/A N/A 21844 G /usr/lib/firefox/firefox 3MiB |
First, CUDA is the newest version 11.1, which does not have a corresponding cuDNN yet according to https://developer.nvidia.com/rdp/cudnn-archive#a-collapse803-110. So, I downloaded cudnn-11.0-linux-x64-v8.0.3.33.tgz. Would this be OK, or I need to install CUDA 11.0 instead? Second, after I extracted cudnn-11.0-linux-x64-v8.0.3.33.tgz,
I did:
$ sudo cp cuda/include/cudnn*.h /usr/local/cuda/include
$ sudo cp cuda/lib64/libcudnn* /usr/local/cuda/lib64
$ sudo chmod a+r /usr/local/cuda/include/cudnn*.h /usr/local/cuda/lib64/libcudnn*
Adding this line at the end of ~/.bashrc:
export CUDA_HOME=/usr/local/cuda
$ source ~/.bashrc
/etc/ld.so.conf.d/999_cuda-11-1.conf was edited from:
/usr/local/cuda-11.1/targets/x86_64-linux/lib
to
/usr/local/cuda/extras/CUPTI/lib64
$ sudo ldconfig
However,
$ cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2has no output. I do have:
/usr/local/cuda/include$ ls -l total 81 -rw-r--r-- 1 root root 29025 Oct 24 20:39 cudnn_adv_infer.h -rw-r--r-- 1 root root 27700 Oct 24 20:39 cudnn_adv_train.h -rw-r--r-- 1 root root 12527 Oct 24 20:39 cudnn_backend.h -rw-r--r-- 1 root root 29011 Oct 24 20:39 cudnn_cnn_infer.h -rw-r--r-- 1 root root 10177 Oct 24 20:39 cudnn_cnn_train.h -rw-r--r-- 1 root root 2968 Oct 24 20:39 cudnn.h -rw-r--r-- 1 root root 48825 Oct 24 20:39 cudnn_ops_infer.h -rw-r--r-- 1 root root 25733 Oct 24 20:39 cudnn_ops_train.h -rw-r--r-- 1 root root 2785 Oct 24 20:39 cudnn_version.h
Did I install cuDNN cuccessfully? Thank you!
