I’m setting up some sandboxed CUDA development environments using
(cuda-dev)$ conda install cuda -c nvidia
(cuda-dev-11.8)$ conda install cuda=11.8 -c nvidia
etc
I was under the impression that this would install an appropriate version of cuDNN, but it doesn’t:
(cuda-dev) pgoetz@finglas python$ conda list | grep cudnn
Further the versions of cudnn available in the nvidia conda channel are quite old:
root@finglas:~# conda search cudnn -c nvidia
Loading channels: done
# Name Version Build Channel
cudnn 7.0.5 cuda8.0_0 pkgs/main
cudnn 7.1.2 cuda9.0_0 pkgs/main
cudnn 7.1.3 cuda8.0_0 pkgs/main
cudnn 7.2.1 cuda9.2_0 pkgs/main
cudnn 7.3.1 cuda10.0_0 pkgs/main
cudnn 7.3.1 cuda9.0_0 pkgs/main
cudnn 7.3.1 cuda9.2_0 pkgs/main
cudnn 7.6.0 cuda10.0_0 nvidia
cudnn 7.6.0 cuda10.0_0 pkgs/main
cudnn 7.6.0 cuda10.1_0 nvidia
cudnn 7.6.0 cuda10.1_0 pkgs/main
cudnn 7.6.0 cuda9.0_0 pkgs/main
cudnn 7.6.0 cuda9.2_0 nvidia
cudnn 7.6.0 cuda9.2_0 pkgs/main
cudnn 7.6.4 cuda10.0_0 pkgs/main
cudnn 7.6.4 cuda10.1_0 pkgs/main
cudnn 7.6.4 cuda9.0_0 pkgs/main
cudnn 7.6.4 cuda9.2_0 pkgs/main
cudnn 7.6.5 cuda10.0_0 pkgs/main
cudnn 7.6.5 cuda10.1_0 pkgs/main
cudnn 7.6.5 cuda10.2_0 pkgs/main
cudnn 7.6.5 cuda9.0_0 pkgs/main
cudnn 7.6.5 cuda9.2_0 pkgs/main
cudnn 8.0.0 cuda10.2_0 nvidia
cudnn 8.0.0 cuda11.0_0 nvidia
cudnn 8.0.4 cuda10.1_0 nvidia
cudnn 8.0.4 cuda10.2_0 nvidia
cudnn 8.0.4 cuda11.0_0 nvidia
cudnn 8.0.4 cuda11.1_0 nvidia
cudnn 8.2.1 cuda11.3_0 pkgs/main
cudnn 8.9.2.26 cuda11_0 pkgs/main
The version of cudnn recommended by Nvidia for CUDA >= 11.8 is 8.9.5.
And if I try to install an older version of cudnn from either the nvidia or the main channel:
(cuda-dev-11.3) root@finglas:~# conda install cudnn -c nvidia
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
environment location: /usr/opt/miniconda/envs/cuda-dev-11.3
added / updated specs:
- cudnn
The following NEW packages will be INSTALLED:
_libgcc_mutex pkgs/main/linux-64::_libgcc_mutex-0.1-main
_openmp_mutex pkgs/main/linux-64::_openmp_mutex-5.1-1_gnu
cudatoolkit pkgs/main/linux-64::cudatoolkit-11.8.0-h6a678d5_0
cudnn pkgs/main/linux-64::cudnn-8.9.2.26-cuda11_0
libgcc-ng pkgs/main/linux-64::libgcc-ng-11.2.0-h1234567_1
libgomp pkgs/main/linux-64::libgomp-11.2.0-h1234567_1
libstdcxx-ng pkgs/main/linux-64::libstdcxx-ng-11.2.0-h1234567_1
Proceed ([y]/n)? n
It appears to want to install an older version of the cudatoolkit when cudatoolkit version 12.2.2 is already installed (for CUDA versions 11.3, 11.8, 12.0, an 12.2 – the only versions I’ve created environments for). I’ve already tried installing cudnn from the nvidia channel in a pytorch environment and it broke everything, so I’m loathe to repeat this experiment.
I’m trying to avoid using pip to install packages in conda, but pip install cudnn couldn’t locate an appropriate package, either.
Any thoughts on how to address this lacuna?
