Preformatted text## Description
Hi there, I have this odd issue when attempting to install CUDA 10.1 (also tried on 10.0). When running the command sudo apt-get install cuda-10-1, I am forced to install all versions of the drivers and metapackages which included newer versions that are not compatible with the CUDA version I am installing.
I have some details here on this issue I posted in GitHub: Installing CUDA onto Ubuntu 18.04 VM is installing all versioned libraries · Issue #131 · NVIDIA/cuda-samples · GitHub
Some other notes:
- I cannot uninstall the *-470 (or any other versions) packages by itself
- Using the instructions for 10.1 CUDA installation
- This was working and installing properly last week… not sure what has changed
- I have completely started from scratch on the VM and have been able to reproduce four times
- The program I am planning to use requires a specific version of CUDA so I cannot budge on versioning
A clear and concise description of the bug or issue.
Environment
TensorRT Version: N/A
GPU Type: NVIDIA Tesla T4
Nvidia Driver Version: 418.39
CUDA Version: 10.1 OR 10.0
CUDNN Version: 7.6.3
Operating System + Version: Ubuntu 18.04.6
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.14
PyTorch Version (if applicable): N/A
Baremetal or Container (if container which image + tag): N/A
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
To reproduce I do the following:
- Downgrade kernel to proper version. In this case 5.0.0
- Download deb file from NVIDIA and install the package
- Attempt to install CUDA 10.1
- CUDA successfully installs but installs all driver and metapackaging versions
- Run nvidia-smi and I get an error:
/usr/bin/nvidia-modprobe: unrecognized option: “-s”
ERROR: Invalid commandline, please run /usr/bin/nvidia-modprobe --help for usage information.
(SEE GitHub LINK FOR nvidia-smi RESULT)
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
When I use dpkg to uinstal the .deb file (CUDA 10.1), add apt-key, and update/install CUDA-- You can see the dependancies that it is attempting to install all versions of the drivers/metapackages.
EX:
nvidia-driver-418
nvidia-driver-430
nvidia-driver-440
so on and so forth
jylag@vm:~$ sudo apt-get install cuda
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
adwaita-icon-theme at-spi2-core binutils binutils-common binutils-x86-64-linux-gnu build-essential ca-certificates-java cpp cpp-7 cuda-10-1 cuda-command-line-tools-10-1 cuda-compiler-10-1 cuda-cudart-10-1
cuda-cudart-dev-10-1 cuda-cufft-10-1 cuda-cufft-dev-10-1 cuda-cuobjdump-10-1 cuda-cupti-10-1 cuda-curand-10-1 cuda-curand-dev-10-1 cuda-cusolver-10-1 cuda-cusolver-dev-10-1 cuda-cusparse-10-1
cuda-cusparse-dev-10-1 cuda-demo-suite-10-1 cuda-documentation-10-1 cuda-driver-dev-10-1 cuda-drivers cuda-gdb-10-1 cuda-gpu-library-advisor-10-1 cuda-libraries-10-1 cuda-libraries-dev-10-1
cuda-license-10-1 cuda-memcheck-10-1 cuda-misc-headers-10-1 cuda-npp-10-1 cuda-npp-dev-10-1 cuda-nsight-10-1 cuda-nsight-compute-10-1 cuda-nsight-systems-10-1 cuda-nvcc-10-1 cuda-nvdisasm-10-1
cuda-nvgraph-10-1 cuda-nvgraph-dev-10-1 cuda-nvjpeg-10-1 cuda-nvjpeg-dev-10-1 cuda-nvml-dev-10-1 cuda-nvprof-10-1 cuda-nvprune-10-1 cuda-nvrtc-10-1 cuda-nvrtc-dev-10-1 cuda-nvtx-10-1 cuda-nvvp-10-1
cuda-runtime-10-1 cuda-samples-10-1 cuda-sanitizer-api-10-1 cuda-toolkit-10-1 cuda-tools-10-1 cuda-visual-tools-10-1 dconf-gsettings-backend dconf-service default-jre default-jre-headless dkms dpkg-dev
fakeroot fonts-dejavu-extra freeglut3 freeglut3-dev g++ g+±7 gcc gcc-7 gcc-7-base glib-networking glib-networking-common glib-networking-services gsettings-desktop-schemas gtk-update-icon-cache
hicolor-icon-theme humanity-icon-theme java-common libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan4 libasound2 libasound2-data libatk-bridge2.0-0 libatk-wrapper-java
libatk-wrapper-java-jni libatk1.0-0 libatk1.0-data libatomic1 libatspi2.0-0 libavahi-client3 libavahi-common-data libavahi-common3 libbinutils libc-dev-bin libc6 libc6-dev libcairo-gobject2 libcc1-0
libcilkrts5 libcolord2 libcroco3 libcublas-dev libcublas10 libcups2 libdconf1 libdpkg-perl libdrm-amdgpu1 libdrm-dev libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libegl-mesa0 libegl1 libepoxy0 libfakeroot
libfile-fcntllock-perl libfontenc1 libgbm1 libgcc-7-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgif7 libgl1 libgl1-mesa-dev libgl1-mesa-dri libglapi-mesa libgles1 libgles2
libglu1-mesa libglu1-mesa-dev libglvnd-core-dev libglvnd-dev libglvnd0 libglx-mesa0 libglx0 libgomp1 libgtk-3-0 libgtk-3-bin libgtk-3-common libice-dev libisl19 libitm1 libjansson4 libjson-glib-1.0-0
libjson-glib-1.0-common liblcms2-2 libllvm10 liblsan0 libmpc3 libmpx2 libnvidia-cfg1-470 libnvidia-common-418 libnvidia-common-430 libnvidia-common-440 libnvidia-common-450 libnvidia-common-460
libnvidia-common-470 libnvidia-compute-418 libnvidia-compute-430 libnvidia-compute-440 libnvidia-compute-450 libnvidia-compute-460 libnvidia-compute-470 libnvidia-decode-418 libnvidia-decode-430
libnvidia-decode-440 libnvidia-decode-450 libnvidia-decode-460 libnvidia-decode-470 libnvidia-encode-418 libnvidia-encode-430 libnvidia-encode-440 libnvidia-encode-450 libnvidia-encode-460
libnvidia-encode-470 libnvidia-extra-470 libnvidia-fbc1-418 libnvidia-fbc1-430 libnvidia-fbc1-440 libnvidia-fbc1-450 libnvidia-fbc1-460 libnvidia-fbc1-470 libnvidia-gl-418 libnvidia-gl-430
libnvidia-gl-440 libnvidia-gl-450 libnvidia-gl-460 libnvidia-gl-470 libnvidia-ifr1-418 libnvidia-ifr1-430 libnvidia-ifr1-440 libnvidia-ifr1-450 libnvidia-ifr1-460 libnvidia-ifr1-470 libopengl0
libpciaccess0 libpcsclite1 libproxy1v5 libpthread-stubs0-dev libquadmath0 librest-0.7-0 librsvg2-2 librsvg2-common libsensors4 libsm-dev libsoup-gnome2.4-1 libsoup2.4-1 libstdc+±7-dev libtsan0 libubsan0
libvdpau1 libwayland-client0 libwayland-cursor0 libwayland-egl1 libwayland-server0 libx11-dev libx11-doc libx11-xcb-dev libx11-xcb1 libxau-dev libxcb-dri2-0 libxcb-dri2-0-dev libxcb-dri3-0 libxcb-dri3-dev
libxcb-glx0 libxcb-glx0-dev libxcb-present-dev libxcb-present0 libxcb-randr0 libxcb-randr0-dev libxcb-render0-dev libxcb-shape0 libxcb-shape0-dev libxcb-sync-dev libxcb-sync1 libxcb-xfixes0
libxcb-xfixes0-dev libxcb1-dev libxcomposite1 libxcursor1 libxdamage-dev libxdamage1 libxdmcp-dev libxext-dev libxfixes-dev libxfixes3 libxfont2 libxft2 libxi-dev libxi6 libxinerama1 libxkbcommon0
libxkbfile1 libxmu-dev libxmu-headers libxnvctrl0 libxrandr2 libxshmfence-dev libxshmfence1 libxt-dev libxtst6 libxv1 libxxf86dga1 libxxf86vm-dev libxxf86vm1 linux-libc-dev make manpages-dev
mesa-common-dev mesa-vdpau-drivers nvidia-compute-utils-418 nvidia-compute-utils-430 nvidia-compute-utils-440 nvidia-compute-utils-450 nvidia-compute-utils-460 nvidia-compute-utils-470 nvidia-dkms-418
nvidia-dkms-430 nvidia-dkms-440 nvidia-dkms-450 nvidia-dkms-460 nvidia-dkms-470 nvidia-driver-418 nvidia-driver-430 nvidia-driver-440 nvidia-driver-450 nvidia-driver-460 nvidia-driver-470
nvidia-kernel-common-418 nvidia-kernel-common-430 nvidia-kernel-common-440 nvidia-kernel-common-450 nvidia-kernel-common-460 nvidia-kernel-common-470 nvidia-kernel-source-418 nvidia-kernel-source-430
nvidia-kernel-source-440 nvidia-kernel-source-450 nvidia-kernel-source-460 nvidia-kernel-source-470 nvidia-modprobe nvidia-prime nvidia-settings nvidia-utils-418 nvidia-utils-430 nvidia-utils-440
nvidia-utils-450 nvidia-utils-460 nvidia-utils-470 openjdk-11-jre openjdk-11-jre-headless pkg-config policykit-1-gnome python3-xkit screen-resolution-extra ubuntu-mono vdpau-driver-all x11-utils
x11-xkb-utils x11proto-core-dev x11proto-damage-dev x11proto-dev x11proto-fixes-dev x11proto-input-dev x11proto-xext-dev x11proto-xf86vidmode-dev xfonts-base xfonts-encodings xfonts-utils
xorg-sgml-doctools xserver-common xserver-xorg-core-hwe-18.04 xserver-xorg-video-nvidia-418 xserver-xorg-video-nvidia-430 xserver-xorg-video-nvidia-440 xserver-xorg-video-nvidia-450
xserver-xorg-video-nvidia-460 xserver-xorg-video-nvidia-470 xtrans-dev
Suggested packages:
binutils-doc cpp-doc gcc-7-locales menu debian-keyring g+±multilib g+±7-multilib gcc-7-doc libstdc++6-7-dbg gcc-multilib autoconf automake libtool flex bison gdb gcc-doc gcc-7-multilib libgcc1-dbg
libgomp1-dbg libitm1-dbg libatomic1-dbg libasan4-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg libasound2-plugins alsa-utils glibc-doc colord cups-common bzr
gvfs libice-doc liblcms2-utils pcscd librsvg2-bin lm-sensors libsm-doc libstdc+±7-doc libxcb-doc libxext-doc libxt-doc make-doc libnss-mdns fonts-ipafont-gothic fonts-ipafont-mincho fonts-wqy-microhei
| fonts-wqy-zenhei fonts-indic libvdpau-va-gl1 nvidia-vdpau-driver nvidia-legacy-340xx-vdpau-driver mesa-utils xfs | xserver xfonts-100dpi | xfonts-75dpi xfonts-scalable
Recommended packages:
libnvidia-compute-470:i386 libnvidia-decode-470:i386 libnvidia-encode-470:i386 libnvidia-ifr1-470:i386 libnvidia-fbc1-470:i386 libnvidia-gl-470:i386
The following NEW packages will be installed:
adwaita-icon-theme at-spi2-core binutils binutils-common binutils-x86-64-linux-gnu build-essential ca-certificates-java cpp cpp-7 cuda cuda-10-1 cuda-command-line-tools-10-1 cuda-compiler-10-1
cuda-cudart-10-1 cuda-cudart-dev-10-1 cuda-cufft-10-1 cuda-cufft-dev-10-1 cuda-cuobjdump-10-1 cuda-cupti-10-1 cuda-curand-10-1 cuda-curand-dev-10-1 cuda-cusolver-10-1 cuda-cusolver-dev-10-1
cuda-cusparse-10-1 cuda-cusparse-dev-10-1 cuda-demo-suite-10-1 cuda-documentation-10-1 cuda-driver-dev-10-1 cuda-drivers cuda-gdb-10-1 cuda-gpu-library-advisor-10-1 cuda-libraries-10-1
cuda-libraries-dev-10-1 cuda-license-10-1 cuda-memcheck-10-1 cuda-misc-headers-10-1 cuda-npp-10-1 cuda-npp-dev-10-1 cuda-nsight-10-1 cuda-nsight-compute-10-1 cuda-nsight-systems-10-1 cuda-nvcc-10-1
cuda-nvdisasm-10-1 cuda-nvgraph-10-1 cuda-nvgraph-dev-10-1 cuda-nvjpeg-10-1 cuda-nvjpeg-dev-10-1 cuda-nvml-dev-10-1 cuda-nvprof-10-1 cuda-nvprune-10-1 cuda-nvrtc-10-1 cuda-nvrtc-dev-10-1 cuda-nvtx-10-1
cuda-nvvp-10-1 cuda-runtime-10-1 cuda-samples-10-1 cuda-sanitizer-api-10-1 cuda-toolkit-10-1 cuda-tools-10-1 cuda-visual-tools-10-1 dconf-gsettings-backend dconf-service default-jre default-jre-headless
dkms dpkg-dev fakeroot fonts-dejavu-extra freeglut3 freeglut3-dev g++ g+±7 gcc gcc-7 gcc-7-base glib-networking glib-networking-common glib-networking-services gsettings-desktop-schemas
gtk-update-icon-cache hicolor-icon-theme humanity-icon-theme java-common libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan4 libasound2 libasound2-data libatk-bridge2.0-0
libatk-wrapper-java libatk-wrapper-java-jni libatk1.0-0 libatk1.0-data libatomic1 libatspi2.0-0 libavahi-client3 libavahi-common-data libavahi-common3 libbinutils libc-dev-bin libc6-dev libcairo-gobject2
libcc1-0 libcilkrts5 libcolord2 libcroco3 libcublas-dev libcublas10 libcups2 libdconf1 libdpkg-perl libdrm-amdgpu1 libdrm-dev libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libegl-mesa0 libegl1 libepoxy0
libfakeroot libfile-fcntllock-perl libfontenc1 libgbm1 libgcc-7-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgif7 libgl1 libgl1-mesa-dev libgl1-mesa-dri libglapi-mesa libgles1
libgles2 libglu1-mesa libglu1-mesa-dev libglvnd-core-dev libglvnd-dev libglvnd0 libglx-mesa0 libglx0 libgomp1 libgtk-3-0 libgtk-3-bin libgtk-3-common libice-dev libisl19 libitm1 libjansson4
libjson-glib-1.0-0 libjson-glib-1.0-common liblcms2-2 libllvm10 liblsan0 libmpc3 libmpx2 libnvidia-cfg1-470 libnvidia-common-418 libnvidia-common-430 libnvidia-common-440 libnvidia-common-450
libnvidia-common-460 libnvidia-common-470 libnvidia-compute-418 libnvidia-compute-430 libnvidia-compute-440 libnvidia-compute-450 libnvidia-compute-460 libnvidia-compute-470 libnvidia-decode-418
libnvidia-decode-430 libnvidia-decode-440 libnvidia-decode-450 libnvidia-decode-460 libnvidia-decode-470 libnvidia-encode-418 libnvidia-encode-430 libnvidia-encode-440 libnvidia-encode-450
libnvidia-encode-460 libnvidia-encode-470 libnvidia-extra-470 libnvidia-fbc1-418 libnvidia-fbc1-430 libnvidia-fbc1-440 libnvidia-fbc1-450 libnvidia-fbc1-460 libnvidia-fbc1-470 libnvidia-gl-418
libnvidia-gl-430 libnvidia-gl-440 libnvidia-gl-450 libnvidia-gl-460 libnvidia-gl-470 libnvidia-ifr1-418 libnvidia-ifr1-430 libnvidia-ifr1-440 libnvidia-ifr1-450 libnvidia-ifr1-460 libnvidia-ifr1-470
libopengl0 libpciaccess0 libpcsclite1 libproxy1v5 libpthread-stubs0-dev libquadmath0 librest-0.7-0 librsvg2-2 librsvg2-common libsensors4 libsm-dev libsoup-gnome2.4-1 libsoup2.4-1 libstdc+±7-dev libtsan0
libubsan0 libvdpau1 libwayland-client0 libwayland-cursor0 libwayland-egl1 libwayland-server0 libx11-dev libx11-doc libx11-xcb-dev libx11-xcb1 libxau-dev libxcb-dri2-0 libxcb-dri2-0-dev libxcb-dri3-0
libxcb-dri3-dev libxcb-glx0 libxcb-glx0-dev libxcb-present-dev libxcb-present0 libxcb-randr0 libxcb-randr0-dev libxcb-render0-dev libxcb-shape0 libxcb-shape0-dev libxcb-sync-dev libxcb-sync1
libxcb-xfixes0 libxcb-xfixes0-dev libxcb1-dev libxcomposite1 libxcursor1 libxdamage-dev libxdamage1 libxdmcp-dev libxext-dev libxfixes-dev libxfixes3 libxfont2 libxft2 libxi-dev libxi6 libxinerama1
libxkbcommon0 libxkbfile1 libxmu-dev libxmu-headers libxnvctrl0 libxrandr2 libxshmfence-dev libxshmfence1 libxt-dev libxtst6 libxv1 libxxf86dga1 libxxf86vm-dev libxxf86vm1 linux-libc-dev make manpages-dev
I’m using debtree to loo. This is my environment:
jylag@vm:~$ uname -r
5.0.0-1034-gcp
jylag@vm:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.6 LTS
Release: 18.04
Codename: bionic
and the dependancies for cuda-drivers are looking like– here’s an example snippet:
jylag@vm:~$ debtree cuda-drivers
digraph “cuda-drivers” {
rankdir=LR;
node [shape=box];
“cuda-drivers” → “libnvidia-common-418” [color=blue,label=“(>= 418.39)”];
“libnvidia-common-418” → “libnvidia-common-430” [color=blue];
“libnvidia-common-430” → “libnvidia-common-440” [color=blue];
“libnvidia-common-440” → “libnvidia-common-450” [color=blue];
“libnvidia-common-450” → “libnvidia-common-460” [color=blue];
“libnvidia-common-460” → “libnvidia-common-470” [color=blue];
“libnvidia-common-470” → “libnvidia-common” [color=red];
“cuda-drivers” → “libnvidia-compute-418” [color=blue,label=“(>= 418.39)”];
“libnvidia-compute-418” → “libnvidia-compute-430” [color=blue];
“libnvidia-compute-430” → “libnvidia-compute-440” [color=blue];
“libnvidia-compute-440” → “libnvidia-compute-450” [color=blue];
“libnvidia-compute-450” → “libnvidia-compute-460” [color=blue];
“libnvidia-compute-460” → “libnvidia-compute-470” [color=blue];
“libnvidia-compute-470” → “libcuda-10.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-10.1-1” [color=red];
“libnvidia-compute-470” → “libcuda-10.2-1” [color=red];
“libnvidia-compute-470” → “libcuda-11.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-11.1-1” [color=red];
“libnvidia-compute-470” → “libcuda-11.2-1” [color=red];
“libnvidia-compute-470” → “libcuda-5.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-5.5-1” [color=red];
“libnvidia-compute-470” → “libcuda-6.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-6.5-1” [color=red];
“libnvidia-compute-470” → “libcuda-7.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-7.5-1” [color=red];
“libnvidia-compute-470” → “libcuda-8.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-9.0-1” [color=red];
“libnvidia-compute-470” → “libcuda-9.1-1” [color=red];
“libnvidia-compute-470” → “libcuda-9.2-1” [color=red];
“libnvidia-compute-470” → “libnvidia-compute” [color=red];
“libnvidia-compute-470” → “nvidia-opencl-icd” [color=red];
“cuda-drivers” → “libnvidia-decode-418” [color=blue,label=“(>= 418.39)”];
“libnvidia-decode-418” → “libnvidia-decode-430” [color=blue];
“libnvidia-decode-430” → “libnvidia-decode-440” [color=blue];
“libnvidia-decode-440” → “libnvidia-decode-450” [color=blue];
“libnvidia-decode-450” → “libnvidia-decode-460” [color=blue];
“libnvidia-decode-460” → “libnvidia-decode-470” [color=blue];
“libnvidia-decode-470” → “libnvidia-compute-470” [color=blue,label=“(= 470.129.06-0ubuntu0.18.04.1)”];
“libnvidia-decode-470” → “libxext6” [color=blue];
“libnvidia-decode-470” → “libnvidia-decode” [color=red];
“cuda-drivers” → “libnvidia-encode-418” [color=blue,label=“(>= 418.39)”];
“libnvidia-encode-418” → “libnvidia-encode-430” [color=blue];
“libnvidia-encode-430” → “libnvidia-encode-440” [color=blue];
“libnvidia-encode-440” → “libnvidia-encode-450” [color=blue];
“libnvidia-encode-450” → “libnvidia-encode-460” [color=blue];
“libnvidia-encode-460” → “libnvidia-encode-470” [color=blue];
“libnvidia-encode-470” → “libnvidia-decode-470” [color=blue];
“libnvidia-encode-470” → “libnvidia-encode” [color=red];
“cuda-drivers” → “libnvidia-fbc1-418” [color=blue,label=“(>= 418.39)”];
“libnvidia-fbc1-418” → “libnvidia-fbc1-430” [color=blue];
“libnvidia-fbc1-430” → “libnvidia-fbc1-440” [color=blue];
“libnvidia-fbc1-440” → “libnvidia-fbc1-450” [color=blue];
“libnvidia-fbc1-450” → “libnvidia-fbc1-460” [color=blue];
“libnvidia-fbc1-460” → “libnvidia-fbc1-470” [color=blue];
“libnvidia-fbc1-470” → “libgl1” [color=blue];
We are moving this post to CUDA related forum to get better help.
Thank you.
