Cannot install cuda to ubuntu 21.04
nvidia driver installed
nvidia-smi gives
 NVIDIA-SMI 465.27       Driver Version: 465.27       CUDA Version: 11.3     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0  On |                  N/A |
| 31%   33C    P8    38W / 430W |    521MiB / 24243MiB |      0%      Default |
|                               |                      |                  N/A |
then
sudo apt install nvidia-cuda-toolkit
but it removes the nvidia driver 465 and installs 460 with
The following additional packages will be installed:
  libnvidia-compute-460 libnvidia-ml-dev nvidia-cuda-dev
Recommended packages:
  libnvcuvid1
The following packages will be REMOVED:
  libnvidia-compute-465 libnvidia-compute-465:i386 libnvidia-decode-465
  libnvidia-decode-465:i386 libnvidia-encode-465 libnvidia-encode-465:i386
  nvidia-compute-utils-465 nvidia-driver-465 nvidia-utils-465
The following NEW packages will be installed:
  libnvidia-compute-460 libnvidia-ml-dev nvidia-cuda-dev nvidia-cuda-toolkit
and
nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Feb_14_21:12:58_PST_2021
Cuda compilation tools, release 11.2, V11.2.152
Build cuda_11.2.r11.2/compiler.29618528_0
but the nvidia driver is mia
nvidia-smi
bash: /usr/bin/nvidia-smi: No such file or directory
obviously cuda requires the nvidia drivers so how do i fix this??
I think sudo apt install nvidia-cuda-toolkit would install cuda toolkit 10.2 and nvidia driver 460 no matter what you have currently installed. You can try with installing specific version of cuda toolkit like: sudo apt install cuda-toolkit-11-1.
But after installing a specific version, the nvcc would have to be added to PATH explicitly.
Hope it helps :)
I also have the same problem, I cannot use cuda toolkit and neither can Nvidia Docker
I just made it! Install Nvidia driver 460, and cuda 11.2. They can match each other successfully!
