I tried to install nvcc on my Ubuntu 22.04 machine following the NVIDIA offical guides and broke my driver 3 times, with a hell lot of headache, and eventually found that this version works.
Installing CUDA Toolkit 12.2 on Ubuntu 22.04
This guide will walk you through the process of installing the CUDA Toolkit 12.2 on Ubuntu 22.04, including setting up the environment variables and verifying the installation.
Steps
1. Remove Previous CUDA Installations and Install the NVIDIA Driver
Ensure that there are no conflicting versions of CUDA or NVIDIA drivers installed, then install the NVIDIA driver version 535.
sudo apt-get --purge remove '*cublas*' 'cuda*' 'nsight*' 'nvidia*'
sudo apt-get autoremove
sudo apt-get install nvidia-driver-535
sudo reboot
2. Download and Install the CUDA Repository Pin
This step ensures that the CUDA repository takes precedence over other repositories.
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/cuda-ubuntu2204.pin
sudo mv cuda-ubuntu2204.pin /etc/apt/preferences.d/cuda-repository-pin-600
3. Download the CUDA Repository Package
Download the CUDA 12.2 repository package for Ubuntu 22.04.
wget https://developer.download.nvidia.com/compute/cuda/12.2.0/local_installers/cuda-repo-ubuntu2204-12-2-local_12.2.0-535.54.03-1_amd64.deb
4. Install the CUDA Repository Package
Use dpkg to install the downloaded package.
sudo dpkg -i cuda-repo-ubuntu2204-12-2-local_12.2.0-535.54.03-1_amd64.deb
5. Install the GPG Key
Install the GPG key to complete the setup.
sudo cp /var/cuda-repo-ubuntu2204-12-2-local/cuda-216F19BD-keyring.gpg /usr/share/keyrings/
6. Update the Package Lists
Update the package lists to include the CUDA repository.
sudo apt-get update
7. Install CUDA Toolkit
Install the CUDA toolkit using apt-get.
sudo apt-get -y install cuda
8. Set Environment Variables
Ensure your environment variables are correctly set by adding the following lines to your .bashrc or .zshrc:
echo 'export PATH=/usr/local/cuda-12.2/bin:$PATH' >> ~/.bashrc
echo 'export LD_LIBRARY_PATH=/usr/local/cuda-12.2/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc
source ~/.bashrc
9. Verify the Installation
Run the following commands to verify that nvidia-smi and nvcc work correctly.
nvidia-smi
nvcc --version
Results:
(us) rong@ubuntu:~$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Jun_13_19:16:58_PDT_2023
Cuda compilation tools, release 12.2, V12.2.91
Build cuda_12.2.r12.2/compiler.32965470_0
(us) rong@ubuntu:~$ nvidia-smi
Wed May 15 09:20:33 2024
| NVIDIA-SMI 535.171.04 Driver Version: 535.171.04 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4080 ... Off | 00000000:01:00.0 On | N/A |
| N/A 47C P8 4W / 150W | 73MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1332 G /usr/lib/xorg/Xorg 69MiB |
