Hi, my nvcc --version worked before. But after some github install from 3rd party, the nvcc does not work anymore… sudo apt-get install libnvcuvid1 does not work neither. >_<
Is there any solution? Thx
nvcc --version
Command 'nvcc' not found, but can be installed with:
sudo apt install nvidia-cuda-toolkit
nvcc -V
(base) ak@ak-MS-7D99:~$ sudo apt install nvidia-cuda-toolkit
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libcuinj64-11.5 : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libnvidia-compute-495-server (>= 495) but it is not installable or
libcuda.so.1 (>= 495) or
libcuda-11.5-1
libnvidia-ml-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libnvidia-ml.so.1 (>= 495)
nvidia-cuda-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libcuda-11.5-1
Recommends: libnvcuvid1 but it is not installable
E: Unable to correct problems, you have held broken packages.
My nvidia-smi works though.
nvidia-smi
Tue Sep 26 01:53:09 2023
| NVIDIA-SMI 535.104.05 Driver Version: 535.104.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 On | 00000000:01:00.0 On | Off |
| 0% 42C P8 25W / 450W | 5177MiB / 24564MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1312 G /usr/lib/xorg/Xorg 128MiB |
| 0 N/A N/A 1593 G /usr/bin/gnome-shell 32MiB |
| 0 N/A N/A 3812 G ...irefox/3131/usr/lib/firefox/firefox 190MiB |
| 0 N/A N/A 10472 C python3 4800MiB |
Package libnvcuvid1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libnvcuvid1' has no installation candidate
