I ran the attached bash script; however, I don’t see nvcc in the command line.
What is missing in the bash script?
What am I doing wrong?
#!/bin/bash
# Create the Download directory if it does not exist and navigate into it
mkdir -p Download
cd Download
# List of file URLs
files=(
"cuda_11.0.2_450.51.05_linux.run"
"7fa2af80.pub"
"libnccl2_2.8.3-1+cuda11.0_amd64.deb"
"libnccl-dev_2.8.3-1+cuda11.0_amd64.deb"
"nvidia-machine-learning-repo-ubuntu2004_1.0.0-1_amd64.deb"
"cudnn-local-repo-ubuntu2004-8.9.6.50_1.0-1_amd64.deb"
"nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-11.8_1.0-1_amd64.deb"
# Download files
for file in "${files[@]}"; do
if [ ! -f "$file" ]; then
wget "http://developer.download.nvidia.com/compute/cuda/11.0.2/local_installers/$file"
if [ $? -ne 0 ]; then
echo "Failed to download $file"
exit 1
fi
fi
done
# Download and move cuda pin
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/cuda-ubuntu2004.pin
sudo mv cuda-ubuntu2004.pin /etc/apt/preferences.d/cuda-repository-pin-600
# Download and install local CUDA repository DEB
wget https://developer.download.nvidia.com/compute/cuda/11.0.3/local_installers/cuda-repo-ubuntu2004-11-0-local_11.0.3-450.51.06-1_amd64.deb
sudo dpkg -i cuda-repo-ubuntu2004-11-0-local_11.0.3-450.51.06-1_amd64.deb
# Add the apt-key
sudo apt-key add /var/cuda-repo-ubuntu2004-11-0-local/7fa2af80.pub
# Update system and install CUDA
sudo apt-get update
sudo apt-get -y install cuda
# Install downloaded packages
sudo dpkg -i libnccl2_2.8.3-1+cuda11.0_amd64.deb
sudo dpkg -i libnccl-dev_2.8.3-1+cuda11.0_amd64.deb
sudo dpkg -i nvidia-machine-learning-repo-ubuntu2004_1.0.0-1_amd64.deb
sudo dpkg -i cudnn-local-repo-ubuntu2004-8.9.6.50_1.0-1_amd64.deb
sudo dpkg -i nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-11.8_1.0-1_amd64.deb
# Fix any potential broken dependencies
sudo apt-get install -f
# Find CUDA version and set CUDA_HOME to correct path
CUDA_VERSION=$(ls /usr/local | grep cuda- | sed 's/cuda-//')
export CUDA_HOME=/usr/local/cuda-$CUDA_VERSION
# Add CUDA_HOME to .bashrc if it doesn't already exist
if ! grep -q "export CUDA_HOME=${CUDA_HOME}" ~/.bashrc ; then
echo "Adding CUDA_HOME to ~/.bashrc"
echo "export CUDA_HOME=${CUDA_HOME}" >> ~/.bashrc
else
echo "CUDA_HOME already exists in ~/.bashrc. Skipping..."
fi
# Go back to the parent directory
cd ..
Reading package lists... Done
Building dependency tree
Reading state information... Done
cuda is already the newest version (11.4.3-1).
0 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
(Reading database ... 260654 files and directories currently installed.)
Preparing to unpack libnccl2_2.8.3-1+cuda11.0_amd64.deb ...
Unpacking libnccl2 (2.8.3-1+cuda11.0) over (2.8.3-1+cuda11.0) ...
Setting up libnccl2 (2.8.3-1+cuda11.0) ...
Processing triggers for libc-bin (2.31-0ubuntu9.12) ...
Preparing to unpack libnccl-dev_2.8.3-1+cuda11.0_amd64.deb ...
Unpacking libnccl-dev (2.8.3-1+cuda11.0) over (2.8.3-1+cuda11.0) ...
Setting up libnccl-dev (2.8.3-1+cuda11.0) ...
Preparing to unpack nvidia-machine-learning-repo-ubuntu2004_1.0.0-1_amd64.deb ...
Unpacking nvidia-machine-learning-repo-ubuntu2004 (1.0.0-1) over (1.0.0-1) ...
Setting up nvidia-machine-learning-repo-ubuntu2004 (1.0.0-1) ...
dpkg-deb: error: 'cudnn-local-repo-ubuntu2004-8.9.6.50_1.0-1_amd64.deb' is not a Debian format archive
dpkg: error processing archive cudnn-local-repo-ubuntu2004-8.9.6.50_1.0-1_amd64.deb (--install):
dpkg-deb --control subprocess returned error exit status 2
Errors were encountered while processing:
Preparing to unpack nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-11.8_1.0-1_amd64.deb ...
Unpacking nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-11.8 (1.0-1) over (1.0-1) ...
Setting up nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-11.8 (1.0-1) ...
my_user_name@192:~$ nvcc
Command 'nvcc' not found, but can be installed with:
sudo apt install nvidia-cuda-toolkit
my_user_name@192:~$
