I thought I had installed the CUDA Toolkit and SDK successfully per the instructions in the getting started pdf. However, the command “nvcc -v” returns “If ‘nvcc’ is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf nvcc”
Is the path not set correctly to the default installation directory? How would one check that?
I’m using OpenSuse 11.2 64bit with a G210 graphics card.
Well, it is working now. I rebooted.
