hi,
i just finished installing CUDA toolkit v2.2 and SDK.When i try to compile the sample codes in the SDK on UBUNTU v 8.10, i am getting the following error
shashwat@mig8gb3-desktop:~/NVIDIA_CUDA_SDK$ make
make[1]: Entering directory /home/shashwat/NVIDIA_CUDA_SDK/common' make[1]: g++: Command not found make[1]: *** [obj/release/bank_checker.cpp.o] Error 127 make[1]: Leaving directory /home/shashwat/NVIDIA_CUDA_SDK/common’
make: *** [lib/libcutil.so] Error 2
also i am not able to get version of nvcc by running the command
when i compile a simple SDK example the deviceQuery.cpp
i gives me error cutil,h not found
i changed the include <cutil.h> to e </home/bibrak/NVIDIA_CUDA_SDK/common/inc/cutil.h>
same i did for the dynamic library.
now it gives the error
bibrak@biebo-laptop:~/NVIDIA_CUDA_SDK/projects/deviceQuery$ nvcc -o dev deviceQuery.cpp
/tmp/tmpxft_000021ff_00000000-1_deviceQuery.o: In function main': deviceQuery.cpp:(.text+0x427): undefined reference to cutCheckCmdLineFlag’
collect2: ld returned 1 exit status
I think your problem is that your nvcc installation is not being able to find the CUDA SDK include and library directories. This is probably a configuration error (sorry).
I’d suggest you try looking into the way you installed the CUDA SDK (i.e. did you install in the default location?) and try getting a small program which just includes <cuda.h> to work without having to tinker with the program’s include directives.
Alternatively, you can try playing with the -I (that’s a capital “i”) and -L compiler flags, in order to point the compiler to the directories where the CUDA SDK header and libraries are located in your filesystem.
Well, it depends on the location your CUDA SDK was installed. In my case, that would be /usr/local/cuda/include for the -I flag and /usr/local/cuda/lib for the -L flag, but again, I get these set by nvcc automatically.
