Installing nvidia-cuda-toolkit
I just freshly installed the Nvidia drivers and CUDA on my Linux computer. After adding the required keyrings,
sudo apt autoremove nvidia* --purge
sudo apt install nvidia-driver-535-server
sudo apt install cuda
After rebooting, nvidia-smi returns the following
| NVIDIA-SMI 535.104.05             Driver Version: 535.104.05   CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 3090        On  | 00000000:01:00.0 Off |                  N/A |
|  0%   38C    P8              14W / 350W |      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
Since I want to use nvcc, I tried installing it with sudo apt install nvidia-cuda-toolkit. But this returns the following
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libcuinj64-11.5 : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
                            libnvidia-compute-495-server (>= 495) but it is not installable or
                            libcuda.so.1 (>= 495) or
                            libcuda-11.5-1
 libnvidia-ml-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
                             libnvidia-ml.so.1 (>= 495)
 nvidia-cuda-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
                            libcuda-11.5-1
                   Recommends: libnvcuvid1 but it is not installable
E: Unable to correct problems, you have held broken packages.
What am I doing wrong :'). Any help will be very much appreciated
I have fixed it with
conda install -c "nvidia/label/cuda-11.7.0" cuda-toolkit
Cheers
