nvdia-smi show CUDA Version, but nvcc not found
I have Ubuntu Server 16.04, VGA: Quadro P4000
nvdia-smi can show CUDA Version, but nvcc -V not found anything.
So is it CUDA installed or not ?
Detail here:
root@ubuntu:/home/ubuntu# nvidia-smi
Tue Nov 13 15:51:15 2018
| NVIDIA-SMI 410.66       Driver Version: 410.66       CUDA Version: 10.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Quadro P4000        Off  | 00000000:02:00.0 Off |                  N/A |
| 46%   36C    P0    28W / 105W |     10MiB /  8119MiB |      0%      Default |
|   1  Quadro P4000        Off  | 00000000:06:00.0 Off |                  N/A |
| 47%   43C    P0    29W / 105W |     10MiB /  8119MiB |      0%      Default |
|   2  Quadro P4000        Off  | 00000000:82:00.0 Off |                  N/A |
| 46%   36C    P0    27W / 105W |     10MiB /  8119MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
root@ubuntu:/home/ubuntu# which nvcc
root@ubuntu:/home/ubuntu# find / -name "nvcc"
root@ubuntu:/home/ubuntu# nvcc --version
The program 'nvcc' is currently not installed. You can install it by typing:
apt install nvidia-cuda-toolkit
root@ubuntu:/home/ubuntu# cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module  410.66  Wed Oct 10 12:01:53 CDT 2018
GCC version:  gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
It’s not installed correctly. If you used a NVIDIA installer to install CUDA, then you may have missed the necessary steps in section 7 of the linux install guide:
[url]Installation Guide Linux :: CUDA Toolkit Documentation
Thanks you for your quick reply.
Because I’m not the man who installed driver & cuda toolkit on this server (someone else did) so I want to verify what he did.
As I can find nvidia-cuda-mps (detail below), I guess that he just install NVIDIA Driver, not CUDA Toolkit. Is it right ?
My main purpose is running ffmpeg transcoding using HW-Accelerating. Do I need to reinstall CUDA Toolkit ?
root@ubuntu:/opt# ls -l /usr/bin/ | grep "nvidia*"
lrwxrwxrwx 1 root   root          52 Oct 26 13:46 nvidia-bug-report.sh -> /etc/alternatives/x86_64-linux-gnu_nvidia_bug_report
lrwxrwxrwx 1 root   root          58 Oct 26 13:46 nvidia-cuda-mps-control -> /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-control
lrwxrwxrwx 1 root   root          57 Oct 26 13:46 nvidia-cuda-mps-server -> /etc/alternatives/x86_64-linux-gnu_nvidia-cuda-mps-server
lrwxrwxrwx 1 root   root          51 Oct 26 13:46 nvidia-debugdump -> /etc/alternatives/x86_64-linux-gnu_nvidia-debugdump
lrwxrwxrwx 1 root   root          54 Oct 26 13:46 nvidia-persistenced -> /etc/alternatives/x86_64-linux-gnu_nvidia_persistenced
-rwxr-xr-x 1 root   root      224736 Oct 17 04:00 nvidia-settings
lrwxrwxrwx 1 root   root          45 Oct 26 13:46 nvidia-smi -> /etc/alternatives/x86_64-linux-gnu_nvidia_smi
lrwxrwxrwx 1 root   root          49 Oct 26 13:46 nvidia-xconfig -> /etc/alternatives/x86_64-linux-gnu_nvidia_xconfig
root@ubuntu:/opt# find / -name "nvcc"
root@ubuntu:/opt#
Finally found out that someone installed Nvidia Driver 410.66 & CUDA Driver (or Runtime ???) Version 10 (nvidia-smi shows in the first post) through graphics-drivers-ubuntu-ppa-xenial.
You have to remove that nvidia driver version, disable that ppa before follow the cuda toolkit official guide or you run into version mismatch.
It means you miss any installation step or it didn’t add to your PATH.
  • check if it is in your PATH by “whereis nvcc”, if it returns “nvcc:” then you need to add below two lines in “.bashrc”
  • usually “.bashrc” file path is like “/home/username/.bashrc” then add below two lines (change cuda version with installed version)
    export PATH=“/usr/local/cuda-11.4/bin:$PATH”
    export LD_LIBRARY_PATH=“/usr/local/cuda-11.4/lib64:$LD_LIBRARY_PATH”
    then save and close the file
  • check “nvcc --version”
Thank you for your solution!
Great solution, thanks so much!
