Hi!
I am trying to install Ubunt 16.1 on my PC (MSI GTX 1080 Ti, Motherboard: ASUS Z170-P). I used nvidia 381 driver by app-get. Additionally I tried another versions of Ubuntu (16.04.1, 14.04.5), another version of driver (378.13). In all cases behaviour the same: after log in you automaticaly and immediatly logout. Also I tried this: NVidia GTX 1080 installation on Ubuntu 16.04 LTS | Abhay Harpale Behaviour the same. How to see what exactly happens internally and how to fix?
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt install nvidia-381* nvidia-settings
reboot
I tried it, it is not work. After login you log out.
I can’t even install Ubuntu and end up with a black screen.
Works fine with integrated graphics (Intel HD 3000) though…
Guess I’ll have to wait for an official 1080 TI support.
Getting same login loop problem here as well, but logging in with guest session works.
Now that I am logged in, my motherboard/CPU’s integrated graphics are not being identified in the displays
Under “All Settings” → Displays only the 1080ti’s monitor is visible and not the two others I have plugged in through the integrated ports that I was using prior to the installation of this graphics card.
During startup the ubuntu logo is on both integrated port’s monitors and not the 1080ti’s monitor. Upon login screen, then the integrated graphics go black.
What to do?!?
$ sudo lshw -c video
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:32 memory:f2000000-f2ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
*-display
product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list
configuration: driver=i915 latency=0
resources: irq:28 memory:f3400000-f37fffff memory:d0000000-dfffffff ioport:f000(size=64)
i remember during the installation of the nvidia-381* driver it did say something about lack of i915 module
@marmac: that would be a multi-gpu setup with gpus from different vendors. Though it kind of works (xinerama), you won’t get happy with this. Connect all monitors to the nvidia card.
best music on a help video, EVER!!
