Good afternoon,
I am trying to generate some PTX code from CUDA code for raygeneration program and all goes will until I try to call optixTrace in the code. When I do, I get the following PTX output error:
ptxas ptxcode.ptx, line 30; error : Call to '_optix_get_launch_index_x' requires call prototype
My defined CMakeLists.txt file uses the arch=sm_60 with CXX standard 17, calling the embedd_optix.cmake CMake macro in the tools/ directory follows:
cmake_minimum_required(VERSION 3.15 FATAL_ERROR)
project(RTX_PROJECT 0.1 LANGUAGES CXX CUDA)
set(CMAKE_CUDA_ARCHITECTURES 60)
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED True)
# OptiX 7.4 headers
set(OPTIX_DIR /path_to_optix_740)
set(OPTIX_INCLUDE ${OPTIX_DIR}/include)
# RF Scene generator headers
set(RTX_INCLUDE ${PROJECT_SOURCE_DIR}/src
${PROJECT_SOURCE_DIR}/src/shaders)
set(CMAKE_CUDA_SEPARABLE_COMPILATION ON)
# Create PTX from shaders
include(tools/embbed_optix.cmake)
embbed_optix_shader(ptxcode src/shaders/ptxcode.cu)
# Files for building executable including the PTX
# CUDA code
set(SOURCES src/driver.cpp
src/shaders/params.hpp
${ptxcode})
add_executable(xRTX ${SOURCES})
# Creates library rtx
add_subdirectory(src/ray_trace)
target_link_directories(xRTX PRIVATE ${OPTIX_DIR})
target_link_libraries(xRTX rtx)
target_include_directories(xRTX PUBLIC ${RTX_INCLUDE}
${OPTIX_INCLUDE})
The following is the cmake macro embbed_optix_shader in the tools/ directory that generates the PTX code during compilation:
set(BIN2C /usr/local/cuda-11/bin/bin2c)
set(OPTIX_INCLUDE /path_to_optix740/include)
macro(embbed_optix_shader output_var shader_file)
add_library(${output_var}_lib OBJECT ${shader_file})
set_target_properties(${output_var}_lib PROPERTIES CUDA_PTX_COMPILATION ON)
target_compile_options(${output_var}_lib PRIVATE --generate-line-info -use_fast_math -arch=sm_60 --keep)
target_include_directories(${output_var}_lib PUBLIC ${OPTIX_INCLUDE})
add_custom_command(
COMMAND ${BIN2C} --padd 0 --type char --name ${output_var} ${output_var}.ptx > ${output_var}.cpp
OUTPUT ${output_var}.cpp
DEPENDS ${output_var}_lib
set(${output_var} ${output_var}.cpp)
endmacro()
I am hoping it is something simple in the above code that is causing the issue - a flag maybe? A line I have neglected to include perhaps?
The CUDA code being compiled via the above cmake macro follows:
#include <cuda_runtime.h>
#include <optix.h>
#include <optix_device.h>
#include <optix_stubs.h>
#include "params.hpp" // launch parameters
#include "sbt.hpp" // base Shader Binding Table
#include "sbt_raygeneration.hpp" // extended SBT for raygeneration
#include "vec_math.hpp" // vector operations
extern "C" {
* @brief Defines OptiX launch parameters that EVERY program
* has access to
__constant__ Params params;
* @brief CUDA raygeneration program for OptiX, generates rays
__global__ void __raygen__render() {
const uint3 idx = optixGetLaunchIndex();
const uint3 dim = optixGetLaunchDimensions();
// Cast SBT to raygeneration SBT
const SbtRaygeneration* rtData = reinterpret_cast<SbtRaygeneration*>(optixGetSbtDataPointer());
const float3 U = rtData->camera_u;
const float3 V = rtData->camera_v;
const float3 W = rtData->camera_w;
const float2 d = 2.0f * make_float2(static_cast<float>(idx.x) / static_cast<float>(dim.x),
static_cast<float>(idx.y) / static_cast<float>(dim.y)) - 1.0f;
const float3 origin = rtData->camera_eye;
const float3 direction = normalize(d.x * U + d.y * V + W);
float3 prd = make_float3(0.5f, 0.5f, 0.5f);
uint32_t p0, p1, p2;
p0 = __float_as_int(prd.x);
p1 = __float_as_int(prd.y);
p2 = __float_as_int(prd.z);
// NOTE: The following appears to generate the problem in PTX code
optixTrace(params.handle, origin, direction, 0.0f, 1e16f, 0.0f, OptixVisibilityMask(1),
OPTIX_RAY_FLAG_NONE, 0, 0, 0, p0, p1, p2);
prd.x = __int_as_float(p0);
prd.y = __int_as_float(p1);
prd.z = __int_as_float(p2);
params.image[idx.y * params.image_width + idx.x] = make_color(prd);
Thank you to anyone with any hints or ideas as to what I am doing wrong.
