Generic Makefile
Here is a generic Makefile that I have been using for some of my projects. I thought it might be useful for someone else that didn’t want to use the SDK templates like I didn’t. Feel free to use it or make sugestions to make it better.
# Makefile
# author      : sam adams
# version     : 0.1
# date        : 20071017
# discription : generic Makefile for making cuda programs
BIN               := gpu_program
# flags
CUDA_INSTALL_PATH := /usr/local/cuda
INCLUDES          += -I. -I$(CUDA_INSTALL_PATH)/include
LIBS              := -L$(CUDA_INSTALL_PATH)/lib
CFLAGS            := -O3
LDFLAGS           := -lrt -lm -lcudart
# compilers
NVCC              := nvcc
CC                := g++
LINKER            := g++
# files
C_SOURCES         := $(wildcard *.c)
CU_SOURCES        := $(wildcard *.cu)
HEADERS           := $(wildcard *.h)
C_OBJS            := $(patsubst %.c, %.o, $(C_SOURCES))
CU_OBJS           := $(patsubst %.cu, %.o, $(CU_SOURCES))
$(BIN): clean $(C_OBJS) $(CU_OBJS) $(HEADERS)
        $(LINKER) -o $(BIN) $(CU_OBJS) $(C_OBJS) $(LDFLAGS) $(INCLUDES) $(LIBS)
$(C_OBJS): $(C_SOURCES) $(HEADERS)
        $(CC) -c $(C_SOURCES) $(CFLAGS) $(INCLUDES)
$(CU_OBJS): $(CU_SOURCES) $(HEADERS)
        $(NVCC) -c $(CU_SOURCES) $(INCLUDES)
run: $(BIN)
        LD_LIBRARY_PATH=$(CUDA_INSTALL_PATH)/lib ./$(BIN)
clean:
        rm -f $(BIN) *.o
Hallo Sam,
I implemented a makefile system for building my application, it can either use MS ‘nmake’ or the classical GNU ‘make’. The strange thing is that nvcc cannot start if I launch it from the ‘make’ tool, while everything is ok if I use GNU ‘make’… see my post
[url=“The Official NVIDIA Forums | NVIDIA”]http://forums.nvidia.com/index.php?showtopic=56803&hl=tasora[/url]
Have you experienced the same thing?
Has someone used ‘nmake’ and nvcc? …
Alessandro Tasora
