I’m a newbie to CUDA and parallel programming so forgive me for my mistakes. I have a C++ program with some code in a function that I’d like to run on the GPU. Originally the program is being compiled with gcc/g++ and I’m trying to modify the makefile for the program so I can compile using nvcc but I’m really stuck on how to integrate everything together, especially the linking stage.
This is the original make file
CC = gcc
CCPP = g++
#preprocessor defines
DEFINES = -DUSE_ZLIB
OPTFLAGS = -O3
#CFLAGS = -ansi -pedantic -Wall -Werror -fPIC
#CFLAGS = -ansi -pedantic -Wall -fPIC
CFLAGS = -ansi $(OPTFLAGS)
CPPFLAGS = $(OPTFLAGS) -I./include $(DEFINES)
LINKFLAGS = -lz
all : simple
objs = src/tourtre.o \
src/ctArc.o \
src/ctBranch.o \
src/ctComponent.o \
src/ctNode.o \
src/ctQueue.o \
src/ctNodeMap.o \
examples/simple/obj/Data.o \
examples/simple/obj/Mesh.o \
examples/simple/obj/main.o
simple : $(objs)
$(CCPP) $(CPPFLAGS) -o simple $^ $(LINKFLAGS)
src/tourtre.o : src/tourtre.c include/tourtre.h src/ctMisc.h include/ctArc.h include/ctNode.h src/ctComponent.h include/ctNode.h src/ctQueue.h src/ctAlloc.h
$(CC) $(CPPFLAGS) $(CFLAGS) -c $< -o $@
src/ctArc.o : src/ctArc.c include/tourtre.h src/ctMisc.h include/ctArc.h
src/ctBranch.o : src/ctBranch.c include/tourtre.h src/ctMisc.h include/ctBranch.h
src/ctComponent.o : src/ctComponent.c include/tourtre.h src/ctMisc.h src/ctComponent.h
src/ctNode.o : src/ctNode.c include/tourtre.h src/ctMisc.h include/ctNode.h
src/ctQueue.o : src/ctQueue.c include/tourtre.h src/ctMisc.h src/ctQueue.h
src/ctNodeMap.o : src/ctNodeMap.c src/ctNodeMap.h include/ctNode.h src/ctQueue.h src/sglib.h
examples/simple/obj/Data.o: examples/simple/src/Data.cpp examples/simple/src/Data.h examples/simple/src/Global.h
$(CCPP) $(CPPFLAGS) $(CFLAGS) -c $< -o $@
examples/simple/obj/Mesh.o: examples/simple/src/Mesh.cpp examples/simple/src/Data.h examples/simple/src/Global.h examples/simple/src/Mesh.h
examples/simple/obj/main.o: examples/simple/src/main.cpp examples/simple/src/Data.h examples/simple/src/Global.h examples/simple/src/Mesh.h
clean :
-rm -rf src/*.o examples/simple/obj/*.o doc/html
The file that contains the GPU code is in examples/simple/src/Mesh.cpp; I wrote a simple function that isn’t called anywhere yet because I want to get the compilation working. I’ve tried modifying the makefile so that nvcc is used instead of g++:
CC = gcc
CCPP = g++
NVCC = /vol/cuda/8.0.61/bin/nvcc
OPTFLAGS = -O3
NVFLAGS = -x cu -Wno-deprecated-gpu-targets
LINKFLAGS = -lz
all : simple
src/ctArc.o \
src/ctBranch.o \
src/ctComponent.o \
src/ctNode.o \
src/ctQueue.o \
src/ctNodeMap.o \
simple : $(objs)
$(CCPP) $(CPPFLAGS) –lcudart -o simple $^ $(LINKFLAGS)
$(NVCC) $(NVFLAGS) –dlink -c $< -o $@
clean :
I’ve been reading some articles about Separate Compilation and Linking of CUDA C++ Device code (Separate Compilation and Linking of CUDA C++ Device Code | NVIDIA Technical Blog) but I can’t seem to get it to work. Honestly I am quite unsure about what I am doing. I’m not sure if it even makes sense to have –dlink -c together because to my knowledge, -c specifies not to link but -dlink specifies to link?
Anyway, when I run make, I get the following error:
make -f Makefile
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/tourtre.c -o src/tourtre.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctArc.c -o src/ctArc.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctBranch.c -o src/ctBranch.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctComponent.c -o src/ctComponent.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctNode.c -o src/ctNode.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctQueue.c -o src/ctQueue.o
gcc -O3 -I./include -DUSE_ZLIB -ansi -O3 -c src/ctNodeMap.c -o src/ctNodeMap.o
g++ -O3 -I./include -DUSE_ZLIB -ansi -O3 -c examples/simple/src/Data.cpp -o examples/simple/obj/Data.o
/vol/cuda/8.0.61/bin/nvcc -x cu -Wno-deprecated-gpu-targets –dlink -c examples/simple/src/Mesh.cpp -o examples/simple/obj/Mesh.o
nvcc fatal : A single input file is required for a non-link phase when an outputfile is specified
Makefile:59: recipe for target 'examples/simple/obj/Mesh.o' failed
make: *** [examples/simple/obj/Mesh.o] Error 1
Help much appreciated.
Thank you
