lilei6
February 24, 2020, 5:25am
1
There is a logitech “BRIO c1000e 4k” usb camera.
I want to get 4K(3840*2160) YUV from this camera and show by Xavier.
I tried the flowing gstreamer pipeline ,but cannot show normally.
GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video0 ! fakesink -v
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = image/jpeg, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.116132873 16179 0x55869f9450 WARN v4l2bufferpool gstv4l2bufferpool.c:790:gst_v4l2_buffer_pool_start:v4l2src0:pool:src Uncertain or not enough buffers, enabling copy threshold
When I tried to save a file , also met the sample problem as follows:
gst-launch-1.0 v4l2src ! ‘video/x-raw, width=(int)3840, height=(int)2160’ ! queue ! videoconvert ! omxh265enc ! h265parse ! qtmux ! filesink location=“4k_1.mp4” -e
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
^Chandling interrupt.
Interrupt: Stopping pipeline …
Interrupt while waiting for EOS - stopping pipeline…
Execution ended after 0:00:12.582481992
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Could you please show the correct pipeline command to get 4k(3840*2160) YUV video from usb camera?
I’ll be appreciated for any help.
DaneLLL
February 24, 2020, 7:36am
2
lilei6
February 24, 2020, 7:46am
3
Hello, DaneLLL
I tried as follows:
v4l2-ctl -d /dev/video0 --list-formats-ext
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=3840,height=2160,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
Execution ended after 0:00:00.001051642
Freeing pipeline …
as well as “device=/dev/video1”, but it doesn’t work
DaneLLL
February 24, 2020, 8:38am
4
So no modes are printed in running:
You should configure the supported mode to gst-launch-1.0 command.
lilei6
February 24, 2020, 8:43am
5
DaneLLL:
no, when runing v4l2-ctl -d /dev/video1 --list-formats-ext
the log is as follows:
nvidia@nvidia:~/Videos/test$ v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘’
Interval: Discrete 0.033s (30.000 fps)
lilei6
February 24, 2020, 8:44am
6
DaneLLL:
and here is
nvidia@nvidia:~/Videos/test$ v4l2-ctl -d /dev/video0 --list-formats-ext
Index : 0
Pixel Format: ‘YUYV’
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.008s (120.000 fps)
Interval: Discrete 0.011s (90.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 2560x1440
Size: Discrete 3840x2160
Size: Discrete 4096x2160
Index : 2
Pixel Format: 'NV12'
DaneLLL
February 24, 2020, 9:55am
7
Looks like 1080p30,YUYV is supported. You may try
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=1920,height=1080,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
