I am getting an error while running the following command: docker compose up -d --build for https://github.com/NVIDIA/GenerativeAIExamples/tree/main/RAG/examples/basic_rag/langchain
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running prestart hook #0: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: WSL environment detected but no adapters were found: unknown
It appears based on the error message text that some nvidia driver is missing.
Can you tell me which driver?
