paul368
February 28, 2025, 12:01am
1
When running in Jupyter or a Brev CLI :
!sudo docker run -it --rm
–gpus ‘“device=4”’
–shm-size=16GB
-e NGC_API_KEY
-v “$LOCAL_NIM_CACHE:/opt/nim/.cache”
-u $(id -u)
-p 9235:8000
nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest
I get the error:
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running prestart hook #0: exit status 1, stdout: , stderr: Using requested mode ‘cdi’
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime (e.g. specify the --runtime=nvidia flag) instead.: unknown.
aryason
February 28, 2025, 12:36am
2
Hello Paul,
What instance type did you provision (GPUs and CSP)?
paul368
February 28, 2025, 9:16am
5
Hi Adam
This is the instance I have :
Paul
Did you modify the command to launch this NIM? For example, it should have two ‘-’ before gpus: “–gpus”
what error do you get when you run:
!docker run -it --rm
–gpus ‘“device=4”’
–shm-size=16GB
-e NGC_API_KEY
-u $(id -u)
-p 9235:8000
-d
Thank you.
I now get this error :
Unable to find image '[nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest](http://nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest)' locally
docker: Error response from daemon: Head "[https://nvcr.io/v2/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2/manifests/latest](https://nvcr.io/v2/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2/manifests/latest)": unknown: {"errors": [{"code": "DENIED", "message": "Payment Required"}]}.
See 'docker run --help'.
But I have credit :
Can I dig into that error further ? WHere does it expect to lookup credit ?
yuweiw
March 13, 2025, 1:13am
9
Could you check your security groups by referring to the #9 first?
Getting this error as well and I have credits. Any solution to this?
yuweiw
April 22, 2025, 10:53am
11
You can refer to this #9 , there are no more credits associated with accounts. Could you try the latest version of VSS?
system
Closed
June 6, 2025, 7:44am
13
