Build a Video Search and Summarization Agent
I am trying to run the notebook “NVIDIA AI Blueprint for Video Search and Summarization: Docker Deployment” and while executing this cell:
!docker run -it --rm \
    --gpus '"device=4"' \
    --shm-size=16GB \
    -e NGC_API_KEY \
    -v "$LOCAL_NIM_CACHE:/opt/nim/.cache" \
    -u $(id -u) \
    -p 9235:8000 \
    -d \
    nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest
I am seing this error:
Unable to find image 'nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest' locally
docker: Error response from daemon: pull access denied for nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
The image llama-3.2-nv-rerankqa-1b-v2:latest seems inaccessible to me .
I have passed through the whole process and it seems that my account should have access.
Can you please, give me some help on this?
Can you show the output following the cell (under Step 1: Set Environment Variables and Login to Docker section):
%%bash
echo “${NGC_API_KEY}” | docker login nvcr.io -u ‘$oauthtoken’ --password-stdin
Hi aryason,
Thanks for your reply.
I get the following message:
WARNING! Your password will be stored unencrypted in /home/ubuntu/.docker/config.json.
redential helper to remove this warning. See
gin/#credentials-storem/engine/reference/commandline/lo
Login Succeeded
It seems like there is an issue with the key used. Can you try to run the commands from build.nvidia.com for this NIM (llama-3.2-nv-rerankqa-1b-v2) on another machine or in the CLI?
In a different machine I ran:
echo "${NGC_API_KEY}" | docker login nvcr.io -u '$oauthtoken' --password-stdin
and got:
WARNING! Your password will be stored unencrypted in /home/rafael/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
Then I ran the docker run from NIM (llama-3.2-nv-rerankqa-1b-v2) and got the same error message:
See 'docker run --help'.
In the page of the NIM (llama-3.2-nv-rerankqa-1b-v2) when I click on “Build with this NIM” and fill out the form below, I get an error message.
Also, when I try the “Hosted API” tab, it says “You need permission to use credits in this account”.
Is it related to the problem that I am having?
Hi @rafael54 , have you installed the NVIDIA Container Toolkit before you run the docker command?
Hi @yuweiw
Thank you for your response.
Actually I do have the NVIDIA Container Toolkit installed.
I checked the installation and ran a sample workload with sudo docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi as described here and everything seems normal.
However, when I try to run the image from http://nvcr.io/nim/nvidia/llama-3.2-nv-rerankqa-1b-v2:latest:
    --gpus all \
    --shm-size=16GB \
    -e NGC_API_KEY \
    -u $(id -u) \
    -p 8000:8000 \
I still have this error:
Run 'docker run --help' for more information
I have tried using both the jupyter notebook provided in the instance from console.brev.dev and also in a separate machine.
Maybe isn’t it related to any permission?
If you cannot pull that NIM then there is an issue with your authentication. Also, the rerank NIM is not gated behind VSS EA.
  1. Can you let us know what Subscriptions you have under: org.ngc.nvidia.com/subscriptions?
    There should be NVIDIA Developer Program and VSS Early Access
  2. Ensure you generate a key through: NGC User Guide - NVIDIA Docs
Hi @aryason
There is only one Subscription under my user: NVIDIA VSS Early Access.
How do I add NVIDIA Developer Program there? In my account Log in | NVIDIA Developer I can see that I am part of the Developer Program:
I really appreciate your time and help.
Have you checked if your Subscription expires?
