Thank you for your detailed information. There are several questions to be confirmed.
- Could you attach your steps to get your
NGC_API_KEYand have you set up the key with the commandexport NGC_API_KEY=<your_ngc_key>? - I see that you have the proxy configuration in the startup through
HTTPS_PROXY. I’m not sure if this will affect the deployment. - Could you check your subcription of the VSS and Developer by the following method #9?
