Warning Unhealthy kubelet Startup probe failed: Get "v1/health/ready": dial tcp 10.1.124.81:8000: connect: connection refused
Hi,When I was running VSS locally, I had a health check failure on the large model roaming pod.
Warning Unhealthy 10s (x20 over 12m) kubelet Liveness probe failed: Get “http://10.1.124.82:8000/v1/health/ready”: dial tcp 10.1.124.82:8000: connect: connection refused
sudo microk8s kubectl describe pod nemo-embedding-embedding-deployment-6649b79d84-kjhpl
Namespace: default
Priority: 0
Service Account: default
Node: wj/10.102.1.158
Start Time: Fri, 14 Mar 2025 06:09:17 +0000
Labels: app=nemo-embedding-embedding-deployment
app.kubernetes.io/instance=vss-blueprint
app.kubernetes.io/name=nemo-embedding
generated_with=helm_builder
hb_version=1.0.0
microservice_version=2.1.0
msb_version=2.5.0
pod-template-hash=6649b79d84
Annotations: cni.projectcalico.org/containerID: 2227869aec3493243b84222eec87ec451ef6fb0380c38323444a5b3cf629b241
cni.projectcalico.org/podIP: 10.1.124.82/32
cni.projectcalico.org/podIPs: 10.1.124.82/32
Status: Running
IP: 10.1.124.82
IPs:
IP: 10.1.124.82
Controlled By: ReplicaSet/nemo-embedding-embedding-deployment-6649b79d84
Containers:
embedding-container:
Container ID: containerd://ad5b45a1cf9e73aaedfe14adc1b1c246dff942956410a24f488a96efb1bbe502
Image: nvcr.io/nim/nvidia/llama-3.2-nv-embedqa-1b-v2:1.3.0
Image ID: nvcr.io/nim/nvidia/llama-3.2-nv-embedqa-1b-v2@sha256:b7ff8b85e9661699f6803ad85a48ed41a5c52212284ca4632a3bd240aee61859
Port: 8000/TCP
Host Port: 0/TCP
State: Running
Started: Fri, 14 Mar 2025 06:21:18 +0000
Last State: Terminated
Reason: Error
Exit Code: 137
Started: Fri, 14 Mar 2025 06:19:18 +0000
Finished: Fri, 14 Mar 2025 06:21:17 +0000
Ready: True
Restart Count: 6
Limits:
nvidia.com/gpu: 0
Requests:
nvidia.com/gpu: 0
Liveness: http-get http://:http/v1/health/ready delay=10s timeout=20s period=30s #success=1 #failure=3
Environment:
NGC_API_KEY: <set to the key ‘NGC_API_KEY’ in secret ‘ngc-api-key-secret’> Optional: false
NVIDIA_VISIBLE_DEVICES: 3
Mounts:
/opt/configs from configs-volume (rw)
/opt/scripts from scripts-cm-volume (rw)
/opt/workload-config from workload-cm-volume (rw)
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-c7hqs (ro)
Conditions:
Type Status
PodReadyToStartContainers True
Initialized True
Ready True
ContainersReady True
PodScheduled True
Volumes:
workload-cm-volume:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
configs-volume:
Optional: false
scripts-cm-volume:
Optional: false
kube-api-access-c7hqs:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional:
DownwardAPI: true
QoS Class: BestEffort
Node-Selectors:
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Type Reason Age From Message
Normal Killing 100s (x6 over 11m) kubelet Container embedding-container failed liveness probe, will be restarted
Normal Pulled 70s (x7 over 13m) kubelet Container image “nvcr.io/nim/nvidia/llama-3.2-nv-embedqa-1b-v2:1.3.0” already present on machine
Normal Created 70s (x7 over 13m) kubelet Created container: embedding-container
Normal Started 69s (x7 over 13m) kubelet Started container embedding-container
Have you create-required-secrets correctly? I see you just uploaded describe information of the pod. You can also attach the log info of the pod. We recommend that you upload the log in a file. Thanks
Sorry about that, the following logs will be sent as files.
This is the embedding pod
sudo microk8s kubectl logs nemo-embedding-embedding-deployment-6649b79d84-5mzgr
pod-embedding-deployment.log (1.9 KB)
I followed the instructions. The tgz file for Helm Chart can also be downloaded normally with NGC_API_KEY
There are no obvious errors in this log. Can you describe your process from the beginning?
system version
(base) wj@wj:~$ lsb_release -a
LSB Version: core-11.1.0ubuntu2-noarch:security-11.1.0ubuntu2-noarch
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
system configuration
graphics: 4 * A100(80G)
memory: 768Gi
Deployed in strict accordance with this process
install-the-nvidia-driver-535.161.08
installing-a-kubernetes-cluster
obtain-ngc-api-key
deploy-the-helm-chart
Since we only have 4 graphics cards, we updated them once according to this process
microk8s has been reinstalled, but the status is normal now
OK, thanks for the detailed information. Could you try to update your Ubuntu to 22.04 according to our prerequisites?
Okay, thank you. We’ll update the system and try again.
I updated the system, reinstalled vss, and documented the installation process.Port 8000 will still time out and the pod will keep restarting.
I can’t locate the problem, can you help me check my installation process is there any errors or omissions?
system version
~$ lsb_release -a
No LSB modules are available.
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
Installation_ process_record
Installation_ process_record.docx (1.7 MB)
embedding pod describe&log
pod-embedding-deployment-describe.log (4.2 KB)
pod-embedding-deployment-log.log (2.0 KB)
Thank you for your detailed information. There are several questions to be confirmed.
  1. Could you attach your steps to get your NGC_API_KEY and have you set up the key with the command export NGC_API_KEY=<your_ngc_key>?
  2. I see that you have the proxy configuration in the startup through HTTPS_PROXY. I’m not sure if this will affect the deployment.
  3. Could you check your subcription of the VSS and Developer by the following method #9?
Thank you for taking the time to reply me on the weekend.
My rerank & embedding pod are already in read state. I will explain how to solve the problem after all problems are handled.
embedding-pod.log (36.2 KB)
rerank-pod.log (753.8 KB)
Now that the rerank & embedding pod is ready, do you not need to focus on NGC_API_KEY anymore?
But I now have a new bug about the vss-blueprint-0 pod. Here is part of the log.
{“level”: “WARNING”, “time”: “2025-03-16 05:14:00.085”, “file_name”: “utils.py”, “file_path”: “/opt/nim/llm/nim_llm_sdk/mem_estimators/utils.py”, “line_number”: “30”, “message”: “Error in fetching config.json from NGC”, “exc_info”: “None”, “stack_info”: “None”}
vss-blueprint-0 pod All logs
vss-blueprint-0.log (10.6 KB)
The vss-blueprint-0 & vss-vss-deployment-5945dc89f8-2s24d are not ready!
sudo watch microk8s kubectl get pod
Hi,The “Error in fetching config.json from NGC” problem which is the last problem that I have solved. The log for the vss-blueprint-0 pod does not appear to have any errors, but the pod still does not start properly, I assume it is downloading data, but I cannot be completely sure.
vss-blueprint-0.log (11.9 KB)
I have a few more questions about deployment that I hope you can help answer
  • The “Error in fetching config.json from NGC” problem which is the last problem that I have solved. The log for the vss-blueprint-0 pod does not appear to have any errors, but the pod still does not start properly, I assume it is downloading data, but I cannot be completely sure.
  • The embedding pod and rerank pod also have the same problem, each reboot will download a lot of data, I don’t know if this is normal.
    Because of the network environment in China, I have to use vpn to deploy VSS, but the network environment is not stable, especially prone to some strange problems, need to try several times, which is very time-consuming.I wonder if you have a solution.
This may be the root cause of your problem. Because the size of the model used by each service is relatively large(should be tens of gigabytes in size), if the network is unstable, it may take a lot of time. Even an exception may occur after the network is interrupted.
Could you try to setup the timeout by referring to our Guide?
I modified the detection time of the nim-llm in the same way and after several failures the vss-blueprint-0 pod was ready.
Modified configuration:
nim-llm.env.livenessProbe.initialDelaySeconds: 604800
nim-llm.env.startupProbe.initialDelaySeconds: 604800
But the VSS - deployment pod does not apply this method.
Different errors occurred when pulling the image.
Pulling image "nvcr.io/nvidia/blueprint/vss-engine:2.2.0"
vss-deployment describe and logs:
vss-describe.log (11.1 KB)
vss-log.log (324 Bytes)
Some other errors occurred during the download process.
vss-describe-other-errors.log (850 Bytes)
I monitored the network traffic, and now I see that the image has stopped downloading, but there is an exception, I am not sure whether this is a permission problem or a problem with the downloaded file.
vss-deployment-last.log (10.3 KB)
Just from the log info below and the “403” HTTP Status Code, it might be still a permission issue.
failed to copy: httpReadSeeker: failed open: server message: insufficient_scope: authorization failed
Could you check your subcription of the VSS and Developer by the following method #9 again?
Hi @capricornus_8 could you try to modify the model from VILA to NVILA?
configuring-for-nvila-research-model
rootcause
Hi,after the modification, 403 is reported immediately when the mirror is pulled.
vss-describe.log (10.9 KB)
Hi @capricornus_8 , could you try the method below to pull the docker first?
docker login nvcr.io -u '$oauthtoken' -p <NGC_API_KEY>
docker pull nvcr.io/nvidia/blueprint/vss-engine:2.2.0
  • If this works, then your k8s secret is not created properly. It might be because you changed the key once, but the k8s secret may not have been updated.
  • If this does not work, problem is with NGC_API_KEY . You can try to regenerate your API Key.
Hi,this command can log in and download normally.
I updated the operating system after modifying the API. So I didn’t modify the AIP KEY in the middle. What should I do next? Should I reset the Secret according to this step?
