Unable to run nv-rerankqa-mistral-4b-v3 NIM Bad Gateway
When I attempt to run the nv-rerankqa-mistral-4b-v3 NIM the first time, I get a Bad Gateway error. Is this an issue with my setup or is this on the NVIDIA side?
I get the following:
== NVIDIA Retriever Text Reranking NIM ==
NVIDIA Release 1.0.2 (build 94101e56e865f68d5dfadb5d02af31d64d86b8eb)
Model: nvidia/nv-rerankqa-mistral-4b-v3
Container image Copyright (c) 2016-2024, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This NIM container is governed by the NVIDIA AI Product Agreement here:
https://www.nvidia.com/en-us/data-center/products/nvidia-ai-enterprise/eula/.
A copy of this license can be found under /opt/nim/LICENSE.
The use of this model is governed by the AI Foundation Models Community License
here: https://docs.nvidia.com/ai-foundation-models-community-license.pdf.
OTEL Logging handler requested, but Python logging auto-instrumentation not set up. Set OTEL_PYTHON_LOGGING_AUTO_INSTRUMENTATION_ENABLED=true to enable logging auto-instrumentation.
downloading nim/nvidia/nv-rerankqa-mistral-4b-v3:3_tokenizer_v3
This could take a while.
–2025-03-03 21:36:15-- https://api.ngc.nvidia.com/v2/org/nim/team/nvidia/models/nv-rerankqa-mistral-4b-v3/versions/3_tokenizer_v3/zip
Resolving api.ngc.nvidia.com (api.ngc.nvidia.com)… 35.166.186.15, 35.165.30.77
Connecting to api.ngc.nvidia.com (api.ngc.nvidia.com)|35.166.186.15|:443… connected.
HTTP request sent, awaiting response… 502 Bad Gateway
2025-03-03 21:36:16 ERROR 502: Bad Gateway.
2025-03-03T21:36:16Z WARNING: tools.nim.ngc_models - Failed to download from nim/nvidia/nv-rerankqa-mistral-4b-v3:3_tokenizer_v3: Failure from NGC CLI -
Hi @eric.ferrara hmm, seems like the NIM isn’t running - can you do a docker ps to see if the container is running?
No, it is not running. This is the first time running it after pulling it, so it is trying to download and cache the necessary data, but failing. I am trying to follow the instructions outlined here: nv-rerankqa-mistral-4b-v3 Model by NVIDIA | NVIDIA NIM.
Can you verify you’re using a working NGC API key?
Can you also confirm you’re using this command to spin up the NIM?
export LOCAL_NIM_CACHE=~/.cache/nim
mkdir -p "$LOCAL_NIM_CACHE"
docker run -it --rm \
    --gpus all \
    --shm-size=16GB \
    -e NGC_API_KEY \
    -v "$LOCAL_NIM_CACHE:/opt/nim/.cache" \
    -u $(id -u) \
    -p 8000:8000 \
    nvcr.io/nim/nvidia/nv-rerankqa-mistral-4b-v3:1.0.2```
Yes. That is exactly the command I am running.
Can you confirm if this issue has been resolved?
It seems like a temporary outage might have caused this.
