You should not need to use DeepStream SDK in this usecase. Please try the following sample:
#include <cstdlib>
#include <cstring>
#include <sstream>
#include <gst/gst.h>
using namespace std;
#define USE(x) ((void)(x))
static GstPipeline *gst_pipeline = nullptr;
static string launch_string;
GstClockTime usec = 1000000;
static int w = 640;
static int h = 480;
int main(int argc, char** argv) {
USE(argc);
USE(argv);
gst_init (&argc, &argv);
GMainLoop *main_loop;
main_loop = g_main_loop_new (NULL, FALSE);
ostringstream launch_stream;
launch_stream
<< "v4l2src name=mysource ! "
<< "video/x-raw,width="<< w <<",height="<< h <<",framerate=30/1,format=YUY2 ! "
<< "nvvidconv ! nvv4l2h264enc ! h264parse ! qtmux ! "
<< "filesink location=a.mp4 ";
launch_string = launch_stream.str();
g_print("Using launch string: %s\n", launch_string.c_str());
GError *error = nullptr;
gst_pipeline = (GstPipeline*) gst_parse_launch(launch_string.c_str(), &error);
if (gst_pipeline == nullptr) {
g_print( "Failed to parse launch: %s\n", error->message);
return -1;
if(error) g_error_free(error);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_PLAYING);
g_usleep(15*usec);
GstElement* src = gst_bin_get_by_name(GST_BIN(gst_pipeline), "mysource");
gst_element_send_event (src, gst_event_new_eos ());
// Wait for EOS message
GstBus *bus = gst_pipeline_get_bus(GST_PIPELINE(gst_pipeline));
gst_bus_poll(bus, GST_MESSAGE_EOS, GST_CLOCK_TIME_NONE);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(gst_pipeline));
g_main_loop_unref(main_loop);
g_print("going to exit \n");
return 0;
Build command:
$ g++ -Wall -std=c++11 test.cpp -o test $(pkg-config --cflags --libs gstreamer-app-1.0)
We run it with Logitech C615 which supports 640x480p30 YUYV.
Please refer to FAQ
Q: I have a USB camera. How can I lauch it on Jetson Nano?
and configure support mode to video/x-raw,width,height,framerate,format.
