Getting error on c++ make file
/usr/lib/gcc/x86_64-linux-gnu/7/…/…/…/x86_64-linux-gnu/Scrt1.o: In function _start': (.text+0x20): undefined reference to main’
collect2: error: ld returned 1 exit status
Makefile:146: recipe for target ‘APP’ failed
make: *** [APP] Error 1
hardware and software :
*CUDA 11.2 *
deepstream 5.0
Graphic card tesla t4
Are you using deepstream 1.0?
Could you use latest DS6.0?
deepstream 5.1 im using , have edited the error message could you re-check?
Below is the CMAKE FILE :
CUDA_VER?=
ifeq ($(CUDA_VER),)
$(error “CUDA_VER is not set”)
endif
APP:= Application-1
CC = g++
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=1.0
NVDS_VERSION:=5.1
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
ifeq ($(TARGET_DEVICE),aarch64)
CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.cpp)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.cpp=.o)
CFLAGS+= -I…/…/…/includes \
    -I /usr/local/cuda-$(CUDA_VER)/include
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS:= $(shell pkg-config --libs $(PKGS))
LIBS+= -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
   -lm -lcuda \
   -Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
%.o: %.cpp $(INCS) Makefile
$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
$(CC) -o $(APP) $(OBJS) $(LIBS)
install: $(APP)
cp -rv $(APP) $(APP_INSTALL_DIR)
clean:
rm -rf $(OBJS) $(APP)
seems there is no main in your source code, it’s a basic compile problem, it’s should be not related to deepstream.
