Hi i’m new to CUDA. I wrote a simple CUDA program. When executing it the program throws
the following runtime exception near cudaFree() call. I’m unable to resolve the problem. Need urgent help.
(I’m running Ubuntu 9.10 Karmic Koala x64 Distribution with GCC 4.4.1.
Using CUDA 2.3 and NVIDIA 190.42 Forcewares)
[codebox]
*** glibc detected *** ./a.out: free(): invalid next size (fast): 0x0000000001038210 ***
======= Backtrace: =========
/lib/libc.so.6[0x7f71c4523dd6]
/lib/libc.so.6(cfree+0x6c)[0x7f71c452870c]
./a.out[0x401157]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7f71c44ccabd]
./a.out[0x400ea9]
======= Memory map: ========
00400000-00414000 r-xp 00000000 08:12 129140 /home/abhishek/Programming/CUDA/a.out
00613000-00614000 r–p 00013000 08:12 129140 /home/abhishek/Programming/CUDA/a.out
00614000-00615000 rw-p 00014000 08:12 129140 /home/abhishek/Programming/CUDA/a.out
01038000-01087000 rw-p 00000000 00:00 0 [heap]
7f71bc000000-7f71bc021000 rw-p 00000000 00:00 0
7f71bc021000-7f71c0000000 —p 00000000 00:00 0
7f71c2bcb000-7f71c2bcc000 rw-p 00000000 00:00 0
7f71c2bcc000-7f71c2ccc000 rw-s 49f54000 00:0f 6319 /dev/nvidia0
7f71c2ccc000-7f71c2dcc000 rw-s 49e51000 00:0f 6319 /dev/nvidia0
7f71c2dcc000-7f71c2ecc000 rw-s 49d4e000 00:0f 6319 /dev/nvidia0
7f71c2ecc000-7f71c2fcc000 rw-s 49c48000 00:0f 6319 /dev/nvidia0
7f71c2fcc000-7f71c2fcd000 rw-s 49c44000 00:0f 6319 /dev/nvidia0
7f71c2fcd000-7f71c2fce000 rw-s f2c0a000 00:0f 6319 /dev/nvidia0
7f71c2fce000-7f71c2fcf000 rw-s 49c43000 00:0f 6319 /dev/nvidia0
7f71c2fcf000-7f71c33d1000 rw-s 4c09a000 00:0f 6319 /dev/nvidia0
7f71c33d1000-7f71c37d3000 rw-s 4e5c6000 00:0f 6319 /dev/nvidia0
7f71c37d3000-7f71c37e9000 r-xp 00000000 08:12 2325 /lib/libz.so.1.2.3.3
7f71c37e9000-7f71c39e8000 —p 00016000 08:12 2325 /lib/libz.so.1.2.3.3
7f71c39e8000-7f71c39e9000 r–p 00015000 08:12 2325 /lib/libz.so.1.2.3.3
7f71c39e9000-7f71c39ea000 rw-p 00016000 08:12 2325 /lib/libz.so.1.2.3.3
7f71c39ea000-7f71c3d23000 r-xp 00000000 08:12 5088 /usr/lib/libcuda.so.190.42
7f71c3d23000-7f71c3e22000 —p 00339000 08:12 5088 /usr/lib/libcuda.so.190.42
7f71c3e22000-7f71c3e5e000 rw-p 00338000 08:12 5088 /usr/lib/libcuda.so.190.42
7f71c3e5e000-7f71c3e86000 rw-p 00000000 00:00 0
7f71c3e86000-7f71c3e8d000 r-xp 00000000 08:12 2291 /lib/librt-2.10.1.so
7f71c3e8d000-7f71c408c000 —p 00007000 08:12 2291 /lib/librt-2.10.1.so
7f71c408c000-7f71c408d000 r–p 00006000 08:12 2291 /lib/librt-2.10.1.so
7f71c408d000-7f71c408e000 rw-p 00007000 08:12 2291 /lib/librt-2.10.1.so
7f71c408e000-7f71c40a5000 r-xp 00000000 08:12 2284 /lib/libpthread-2.10.1.so
7f71c40a5000-7f71c42a4000 —p 00017000 08:12 2284 /lib/libpthread-2.10.1.so
7f71c42a4000-7f71c42a5000 r–p 00016000 08:12 2284 /lib/libpthread-2.10.1.so
7f71c42a5000-7f71c42a6000 rw-p 00017000 08:12 2284 /lib/libpthread-2.10.1.so
7f71c42a6000-7f71c42aa000 rw-p 00000000 00:00 0
7f71c42aa000-7f71c42ac000 r-xp 00000000 08:12 2211 /lib/libdl-2.10.1.so
7f71c42ac000-7f71c44ac000 —p 00002000 08:12 2211 /lib/libdl-2.10.1.so
7f71c44ac000-7f71c44ad000 r–p 00002000 08:12 2211 /lib/libdl-2.10.1.so
7f71c44ad000-7f71c44ae000 rw-p 00003000 08:12 2211 /lib/libdl-2.10.1.so
7f71c44ae000-7f71c4614000 r-xp 00000000 08:12 2197 /lib/libc-2.10.1.so
7f71c4614000-7f71c4813000 —p 00166000 08:12 2197 /lib/libc-2.10.1.so
7f71c4813000-7f71c4817000 r–p 00165000 08:12 2197 /lib/libc-2.10.1.so
7f71c4817000-7f71c4818000 rw-p 00169000 08:12 2197 /lib/libc-2.10.1.so
7f71c4818000-7f71c481d000 rw-p 00000000 00:00 0
7f71c481d000-7f71c4833000 r-xp 00000000 08:12 2223 /lib/libgcc_s.so.1
7f71c4833000-7f71c4a32000 —p 00016000 08:12 2223 /lib/libgcc_s.so.1
7f71c4a32000-7f71c4a33000 r–p 00015000 08:12 2223 /lib/libgcc_s.so.1
7f71c4a33000-7f71c4a34000 rw-p 00016000 08:12 2223 /lib/libgcc_s.so.1
7f71c4a34000-7f71c4ab6000 r-xp 00000000 08:12 2239 /lib/libm-2.10.1.so
7f71c4ab6000-7f71c4cb6000 —p 00082000 08:12 2239 /lib/libm-2.10.1.so
7f71c4cb6000-7f71c4cb7000 r–p 00082000 08:12 2239 /lib/libm-2.10.1.so
7f71c4cb7000-7f71c4cb8000 rw-p 00083000 08:12 2239 /lib/libm-2.10.1.so
7f71c4cb8000-7f71c4daa000 r-xp 00000000 08:12 9519 /usr/lib/libstdc++.so.6.0.13
7f71c4daa000-7f71c4faa000 —p 000f2000 08:12 9519 /usr/lib/libstdc++.so.6.0.13
7f71c4faa000-7f71c4fb1000 r–p 000f2000 08:12 9519 /usr/lib/libstdc++.so.6.0.13
7f71c4fb1000-7f71c4fb3000 rw-p 000f9000 08:12 9519 /usr/lib/libstdc++.so.6.0.13
7f71c4fb3000-7f71c4fc8000 rw-p 00000000 00:00 0
7f71c4fc8000-7f71c5006000 r-xp 00000000 08:12 138540 /usr/local/cuda/lib64/libcudart.so.2.3
7f71c5006000-7f71c5206000 —p 0003e000 08:12 138540 /usr/local/cuda/lib64/libcudart.so.2.3
7f71c5206000-7f71c5207000 r–p 0003e000 08:12 138540 /usr/local/cuda/lib64/libcudart.so.2.3
7f71c5207000-7f71c5208000 rw-p 0003f000 08:12 138540 /usr/local/cuda/lib64/libcudart.so.2.3
7f71c5208000-7f71c5227000 r-xp 00000000 08:12 2173 /lib/ld-2.10.1.so
7f71c53fe000-7f71c540f000 rw-s 4e58d000 00:0f 6319 /dev/nvidia0
7f71c540f000-7f71c5414000 rw-p 00000000 00:00 0
7f71c5420000-7f71c5421000 rw-s f2c08000 00:0f 6319 /dev/nvidia0
7f71c5421000-7f71c5422000 rw-s 4c091000 00:0f 6319 /dev/nvidia0
7f71c5422000-7f71c5423000 r–s f2009000 00:0f 6319 /dev/nvidia0
7f71c5423000-7f71c5426000 rw-p 00000000 00:00 0
7f71c5426000-7f71c5427000 r–p 0001e000 08:12 2173 /lib/ld-2.10.1.so
7f71c5427000-7f71c5428000 rw-p 0001f000 08:12 2173 /lib/ld-2.10.1.soAborted
[/codebox]
