Hello, I’m trying to make a simple Cuda program in Linux, using autotools (as instructions found in the forum), but I’m having a segmentation fault when I try to use cudaMalloc, here’s the snippet of code that’s giving me error:
size_t popMemSize = sizeof(Individual)*POPULATION;
size_t latMemSize = sizeof(Lattice)*MAX_LATS;
Lattice *d_lat=NULL;
Individual *d_pop=NULL;
cudaError_t d_error = cudaSuccess;
//Allocating device memory
d_error = cudaMalloc((void**)&d_pop,popMemSize);
printError(stderr,d_error,"cudaMalloc");
d_error = cudaMalloc((void**)&d_lat,latMemSize);
And the structures I’m trying to allocate:
#define LAT_SIZE 149
#define RULE_SIZE 128
#define POPULATION 100
#define MAX_LATS 100
typedef struct Lattice
char cells[LAT_SIZE];
unsigned int density;
}Lattice;
typedef struct Individual
char rule[RULE_SIZE+1];
unsigned int fitness;
}Individual;
This is the error:
Allocating population on device...
*** glibc detected *** src/cuCga: free(): invalid next size (fast): 0x0000000000952500 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x76196)[0x7f4c0cd36196]
/lib64/libc.so.6(cfree+0x6c)[0x7f4c0cd3c3dc]
/lib64/ld-linux-x86-64.so.2(+0x638b)[0x7f4c1169e38b]
/lib64/ld-linux-x86-64.so.2(+0x837a)[0x7f4c116a037a]
/lib64/ld-linux-x86-64.so.2(+0x132d9)[0x7f4c116ab2d9]
/lib64/ld-linux-x86-64.so.2(+0xe826)[0x7f4c116a6826]
/lib64/ld-linux-x86-64.so.2(+0x12ce7)[0x7f4c116aace7]
/lib64/libdl.so.2(+0xf36)[0x7f4c0cabcf36]
/lib64/libdl.so.2(+0x127c)[0x7f4c0cabd27c]
/lib64/libdl.so.2(dlopen+0x31)[0x7f4c0cabceb1]
/usr/local/cuda/lib64/libcudart.so.2(+0x8c31)[0x7f4c11460c31]
/usr/local/cuda/lib64/libcudart.so.2(+0x31124)[0x7f4c11489124]
/usr/local/cuda/lib64/libcudart.so.2(+0x315df)[0x7f4c114895df]
/usr/local/cuda/lib64/libcudart.so.2(cudaMalloc+0x2e)[0x7f4c1146e48e]
src/cuCga[0x401320]
src/cuCga[0x400e1f]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x7f4c0ccdeb6d]
src/cuCga[0x400ca9]
======= Memory map: ========
00400000-00404000 r-xp 00000000 08:23 2225626 /home/zarnick/programacao/cuda/cuCga/src/cuCga
00603000-00604000 rw-p 00003000 08:23 2225626 /home/zarnick/programacao/cuda/cuCga/src/cuCga
0094b000-0096c000 rw-p 00000000 00:00 0 [heap]
7f4c08000000-7f4c08021000 rw-p 00000000 00:00 0
7f4c08021000-7f4c0c000000 ---p 00000000 00:00 0
7f4c0c483000-7f4c0c497000 r-xp 00000000 08:22 195450 /usr/lib64/libz.so.1.2.3
7f4c0c497000-7f4c0c696000 ---p 00014000 08:22 195450 /usr/lib64/libz.so.1.2.3
7f4c0c696000-7f4c0c697000 rw-p 00013000 08:22 195450 /usr/lib64/libz.so.1.2.3
7f4c0c697000-7f4c0c69e000 r-xp 00000000 08:22 26258 /lib64/librt-2.11.1.so
7f4c0c69e000-7f4c0c89d000 ---p 00007000 08:22 26258 /lib64/librt-2.11.1.so
7f4c0c89d000-7f4c0c89e000 r--p 00006000 08:22 26258 /lib64/librt-2.11.1.so
7f4c0c89e000-7f4c0c89f000 rw-p 00007000 08:22 26258 /lib64/librt-2.11.1.so
7f4c0c89f000-7f4c0c8b6000 r-xp 00000000 08:22 26142 /lib64/libpthread-2.11.1.so
7f4c0c8b6000-7f4c0cab6000 ---p 00017000 08:22 26142 /lib64/libpthread-2.11.1.so
7f4c0cab6000-7f4c0cab7000 r--p 00017000 08:22 26142 /lib64/libpthread-2.11.1.so
7f4c0cab7000-7f4c0cab8000 rw-p 00018000 08:22 26142 /lib64/libpthread-2.11.1.so
7f4c0cab8000-7f4c0cabc000 rw-p 00000000 00:00 0
7f4c0cabc000-7f4c0cabe000 r-xp 00000000 08:22 26263 /lib64/libdl-2.11.1.so
7f4c0cabe000-7f4c0ccbe000 ---p 00002000 08:22 26263 /lib64/libdl-2.11.1.so
7f4c0ccbe000-7f4c0ccbf000 r--p 00002000 08:22 26263 /lib64/libdl-2.11.1.so
7f4c0ccbf000-7f4c0ccc0000 rw-p 00003000 08:22 26263 /lib64/libdl-2.11.1.so
7f4c0ccc0000-7f4c0ce28000 r-xp 00000000 08:22 19013 /lib64/libc-2.11.1.so
7f4c0ce28000-7f4c0d027000 ---p 00168000 08:22 19013 /lib64/libc-2.11.1.so
7f4c0d027000-7f4c0d02b000 r--p 00167000 08:22 19013 /lib64/libc-2.11.1.so
7f4c0d02b000-7f4c0d02c000 rw-p 0016b000 08:22 19013 /lib64/libc-2.11.1.so
7f4c0d02c000-7f4c0d031000 rw-p 00000000 00:00 0
7f4c0d031000-7f4c0d047000 r-xp 00000000 08:22 27934 /usr/lib64/libgcc_s.so.1
7f4c0d047000-7f4c0d247000 ---p 00016000 08:22 27934 /usr/lib64/libgcc_s.so.1
7f4c0d247000-7f4c0d248000 rw-p 00016000 08:22 27934 /usr/lib64/libgcc_s.so.1
7f4c0d248000-7f4c0d335000 r-xp 00000000 08:22 36803 /usr/lib64/libstdc++.so.6.0.13
7f4c0d335000-7f4c0d535000 ---p 000ed000 08:22 36803 /usr/lib64/libstdc++.so.6.0.13
7f4c0d535000-7f4c0d53c000 r--p 000ed000 08:22 36803 /usr/lib64/libstdc++.so.6.0.13
7f4c0d53c000-7f4c0d53e000 rw-p 000f4000 08:22 36803 /usr/lib64/libstdc++.so.6.0.13
7f4c0d53e000-7f4c0d553000 rw-p 00000000 00:00 0
7f4c0d553000-7f4c0d5d5000 r-xp 00000000 08:22 19018 /lib64/libm-2.11.1.so
7f4c0d5d5000-7f4c0d7d4000 ---p 00082000 08:22 19018 /lib64/libm-2.11.1.so
7f4c0d7d4000-7f4c0d7d5000 r--p 00081000 08:22 19018 /lib64/libm-2.11.1.so
7f4c0d7d5000-7f4c0d7d6000 rw-p 00082000 08:22 19018 /lib64/libm-2.11.1.so
7f4c0d7d6000-7f4c0de5b000 r-xp 00000000 08:22 19003 /usr/lib64/libcuda.so.195.30
7f4c0de5b000-7f4c0df5a000 ---p 00685000 08:22 19003 /usr/lib64/libcuda.so.195.30
7f4c0df5a000-7f4c0dfef000 rw-p 00684000 08:22 19003 /usr/lib64/libcuda.so.195.30
7f4c0dfef000-7f4c11458000 rw-p 00000000 00:00 0
7f4c11458000-7f4c11496000 r-xp 00000000 08:22 1444127 /usr/local/cuda/lib64/libcudart.so.2.3
7f4c11496000-7f4c11696000 ---p 0003e000 08:22 1444127 /usr/local/cuda/lib64/libcudart.so.2.3
7f4c11696000-7f4c11697000 r--p 0003e000 08:22 1444127 /usr/local/cuda/lib64/libcudart.so.2.3
7f4c11697000-7f4c11698000 rw-p 0003f000 08:22 1444127 /usr/local/cuda/lib64/libcudart.so.2.3
7f4c11698000-7f4c116b8000 r-xp 00000000 08:22 26285 /lib64/ld-2.11.1.so
7f4c1187b000-7f4c11882000 rw-p 00000000 00:00 0
7f4c118b6000-7f4c118b7000 rw-p 00000000 00:00 0
7f4c118b7000-7f4c118b8000 r--p 0001f000 08:22 26285 /lib64/ld-2.11.1.so
7f4c118b8000-7f4c118b9000 rw-p 00020000 08:22 26285 /lib64/ld-2.11.1.so
7f4c118b9000-7f4c118ba000 rw-p 00000000 00:00 0
7fff60f3e000-7fff60f53000 rw-p 00000000 00:00 0 [stack]
7fff60fff000-7fff61000000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Aborted
Thinking it could be the size I was trying to allocate, I reduced the values, but had no luck, any tips?
