I’m using a Quadro 2000 and am attempting to develop a CUDA function. I get a segmentation fault in the first cudaMalloc Call. Let me give some data:
- Setup: Setup is fine. I compiled the samples and ran a few - they ran fine.
- Makefile: I cannibalized a Makefile out of the samples to create the makefile that I use. So I assume the right environment is discovered, the right flags are being set and the compilation is fine.
- I have just two files at this point (a main.cpp - which was originally a c file that I renamed - it is fairly simple c code - essentially initializing a few structs, calling cuda setup functions and then calling the __global__ function
- like I said, I get the segmentation fault right at the first cudaMalloc call.
- x is not running. I'm on the console.
I’m completely unable to figure out what I’m doing wrong.
Let me paste some code & output here:
gpuErrChk is an inline function as follows
#define gpuErrChk(ans) {gpuAssert((ans), FILE, LINE);}
and
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
if (code != cudaSuccess)
fprintf(stderr,“GPUassert: %s %s %d\n”, cudaGetErrorString(code), file, line);
if (abort) exit(code);
Dbg dumps debug info…
OK. the Cuda call sequence is as follows:
gpuErrChk (cudaGetDeviceCount (&gc → dev_count));
Dbg(“Device count %d”, gc → dev_count);
DEBUG cuda_milib.cu:gpu_configuration:29: Device count 1
if (gc -> dev_count) { // set blocks & threads
gpuErrChk (cudaGetDeviceProperties (gc -> dev_prop, i));
Dbg ("Dev prop name: %s, tot_mem: %u sharedMemPerBlock %u\nwarpSize %d maxThreadsPerBlock %d\nmem clockrate %d, mem buswidth %d l2 cache size %d,\nmaxthreads per mprocessor %d", gc -> dev_prop -> name ,
(unsigned) gc -> dev_prop -> totalGlobalMem, (unsigned) gc -> dev_prop -> sharedMemPerBlock,
gc -> dev_prop -> warpSize, gc -> dev_prop -> maxThreadsPerBlock,
gc -> dev_prop -> memoryClockRate, gc -> dev_prop -> memoryBusWidth,
gc -> dev_prop -> l2CacheSize, gc -> dev_prop -> maxThreadsPerMultiProcessor);
DEBUG cuda_milib.cu:gpu_configuration:54: Dev prop name: Quadro 2000, tot_mem: 1073414144 sharedMemPerBlock 49152
warpSize 32 maxThreadsPerBlock 1024
mem clockrate 1304000, mem buswidth 128 l2 cache size 262144,
maxthreads per mprocessor 1536
The next line is:
Dbg (“Mem asked for %u”, sizeof(record_node)*MAX_RECORDS);
DEBUG cuda_milib.cu:gpu_load_records:66: Mem asked for 19899288
The memory asked for is far lower than the available memory…
and then I call:
gpuErrChk (cudaMalloc ((void **) &(ig → gpu_nodes), sizeof (record_node)*MAX_RECORDS));
and I get a core dump:
I ran this again in cuda-gdb and logged data into gdb.txt. The output (including backtrace is as follows)
[i]rinka@rinka-Desktop:~/Documents/dev/code/milib$ cat gdb.txt
Starting program: /home/rinka/Documents/dev/code/milib/milib
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
[New Thread 0x7ffff47e1700 (LWP 4031)]
[New Thread 0x7ffff37e0700 (LWP 4032)]
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff4c57f26 in cuVDPAUCtxCreate () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#0 0x00007ffff4c57f26 in cuVDPAUCtxCreate () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#1 0x00007ffff4c25b8f in cuMemAlloc_v2 () from /usr/lib/x86_64-linux-gnu/libcuda.so.1
#2 0x0000000000430633 in cudart::driverHelper::mallocPtr(unsigned long, void**) ()
#3 0x000000000040d79e in cudart::cudaApiMalloc(void**, unsigned long) ()
#4 0x00000000004409cf in cudaMalloc ()
#5 0x000000000040362a in gpu_load_records(input_to_gpu_interface*) ()
#6 0x0000000000402bff in load_records(input_to_gpu_interface*) ()
#7 0x0000000000402783 in main ()
quit
A debugging session is active.
Inferior 1 [process 4020] will be killed.
Quit anyway? (y or n)
[/i]
