GLM-5.2 (unpruned) @ 200K context on 4× DGX Spark — 27 tok/s single / 52.5 tok/s @c4
Serving GLM-5.2 QuantTrio Int4-Int8Mix (unpruned, all 256 experts — no REAP) across
4× NVIDIA DGX Spark (GB10, sm_121, aarch64, 128G unified each) via vLLM native
multi-node (TP=4, mp executor, no Ray):
⁃	✅ 200K context — exactly 200,064-token KV pool on fp8_ds_mla (DeepSeek-style MLA KV)
⁃	✅ 27.0 tok/s single-stream (warm median) · 30.7 @c2 · 52.5 tok/s @c4 aggregate
⁃	✅ MTP speculative decoding (k=4, lossless) + FLASHMLA_SPARSE + DSA sparse attention
⁃	✅ Reasoning + tool-calling parsers working (glm45 / glm47)
⁃	➕ Optional: vision bolted on via a sidecar VLM — zero GPU cost on the cluster (see below)
This is a reproduction + extension of tonyd2wild’s recipe
(GLM-5.2-QuantTrio-200K-4x-DGX-Spark,
built on eugr/spark-vllm-docker tooling).
Our numbers confirm his @c4 (52.5 vs his 53.5) on independent hardware. What we add: one
build gotcha that cost us a full rebuild to find — worth reading even if you serve a
different model with this tooling.
⚠️ THE gotcha: “preset PRs” silently drift your pinned vLLM ref
The eugr-style Dockerfile defaults to VLLM_APPLY_PRESET_PRS=“” (auto), which applies
preset PRs (47392 + 47618) by running git merge pr-NNNN on top of the pinned ref
(ab666069). The trap:
PR branches get rebased onto newer vLLM main over time. So the merge silently pulls
in a week+ of unrelated mainline drift. Your “pinned” build isn’t pinned — our
version string showed dev851+g84710906a instead of dev190+gab6660699.
For GLM-5.2 that drift broke fp8_ds_mla KV page-padding: page_size_padded came back
None, and the plain-view reshape branch in gpu/attn_utils.py crashed with:
shape ‘[N, 64, 576]’ is invalid for input of size N64656
(656 physical = 512 fp8 + 128 bf16 rope + 16 scale; 576 logical — the padding-aware path
never engaged.)
The fix: build PURE ab666069
1.	Dockerfile: ARG VLLM_APPLY_PRESET_PRS="0" — no preset merges.
2.	One hard patch -p1 in the build (Gemma4 share_embeddings, llm_base_proposer.py)
3.	then fails to apply — make it tolerant (|| echo skip). It's Gemma-only; GLM
4.	doesn't need it. All other TEMPORARY PATCH steps are soft python/sed with skip-fallbacks.
5.	Verify the built version string is exactly dev190+gab6660699.
The presets exist for OTHER models (Gemma4 / DiffusionGemma / MiniMax / Qwen). GLM-5.2’s
fp8_ds_mla support is in ab666069 itself.
General takeaway: any pin-and-merge-PRs build system drifts silently as PR branches
rebase. Always verify the final version string matches your pinned ref.
Stack
Component Value
Checkpoint QuantTrio/GLM-5.2-Int4-Int8Mix — unpruned 256 experts, 405G on disk → 98.08 GiB weights/node at TP=4
vLLM built from source at pure ab666069 (see gotcha above), eugr/spark-vllm-docker tooling
KV cache fp8_ds_mla (MLA compressed), --kv-cache-memory-bytes 10950000000, GMU 0.91 → 200,064-token pool
Speculative MTP k=4, draft_tp=1, FLASHMLA_SPARSE backend — accept length 3.0–3.2 on our pair (author: 3.3–3.6; explains our 27.0 vs his 28.8 single-stream)
Attention DSA sparse indexer; cudagraph FULL (auto → FULL_AND_PIECEWISE for the indexer)
Kernels 10 CosmicRaisins sm12x Triton kernels bind-mounted into the container
Concurrency --max-num-seqs 6 — needs the indexer MTP-overhang patch (included as a mod)
Parsers --reasoning-parser glm45 --tool-call-parser glm47
Cluster vLLM native multi-node (mp executor): head = rank0 local, workers launched via ssh — no Ray
Fabric NCCL over IB: NCCL_IB_HCA=mlx5_1, iface enp1s0f1np1 — IB confirmed by throughput (52.5 @c4 is impossible over TCP fallback)
Boot ~10.5 min (weight load + cudagraph capture)
Benchmarks (256-token probes, temp 0, warm engine)
stream ours (2026-07-12) recipe author
single (warm median) 27.0 tok/s 28.8
concurrency 2 (aggregate) 30.7 37.6
concurrency 4 (aggregate) 52.5 53.5 ✓
The single-stream gap tracks MTP accept length (3.0–3.2 vs 3.3–3.6) — workload/content
dependent, not a config difference. @c4 matches the author’s.
Optional: adding vision to a text-only GLM — sidecar VLM at the proxy
GLM-5.2 is text-only. We gave it practical image support without touching the model or
spending a single GB of cluster memory, by handling vision at the proxy layer:
client (any: OpenAI- or Anthropic-format)
│ request may contain image blocks
thin proxy in front of vLLM
│ detects images → sends them to the sidecar VLM → gets a detailed description
│ → REPLACES the image block with that text → forwards to GLM-5.2
GLM-5.2 (4× DGX Spark) answers over the description
⁃	Sidecar VLM: Qwen3-VL-30B-A3B (30.5B total / 3.3B active MoE, native vision,
⁃	32-lang OCR) running on an Apple Mac Studio via MLX — a machine that was idle
⁃	anyway. The GB10 cluster stays 100% dedicated to GLM.
⁃	Captioning call: non-streaming, temperature 0, generous max_tokens (~1500) so
⁃	descriptions are deterministic and detailed. If the VLM is down, the proxy degrades
⁃	gracefully (inserts a "(vision model unavailable)" note instead of failing the request).
⁃	Client-transparent: Claude-style and OpenAI-style clients get image support with
⁃	zero client-side changes — they think the text model has eyes.
Gotcha we hit: mlx-vlm’s bundled threaded server had a streaming bug (“no Stream”
errors) on this model — we run a small custom main-thread OpenAI-compatible server
around mlx-vlm instead. If you see stream errors from mlx-vlm’s server, that’s your fix.
Honest tradeoff: this is description-based vision — the LLM reasons over a caption,
not pixels. Excellent for screenshots, documents, diagrams, UI questions and OCR-ish
tasks; weaker than a native VLM for fine-grained spatial/pixel-exact queries. For a
text-only frontier model it’s a remarkably cheap 90% solution.
Operational gotchas (all hit live)
1.	Preset-PR drift (above) — the big one. Verify your version string.
2.	Page-cache stall during weight load on GB10 unified memory — run a drop-caches
3.	loop (echo 3 > /proc/sys/vm/drop_caches on ALL nodes every 60s) for the duration of
4.	the ~98G/node load, or the load wedges.
5.	--max-num-seqs > 1 needs the indexer MTP-overhang patch — without it the DSA
6.	indexer overruns under concurrent MTP drafting.
7.	Never SIGKILL / docker rm -f CUDA processes on GB10 — unified-memory GPU
8.	allocations leak unreclaimably until reboot. Stop gracefully (SIGTERM / clean stop
9.	script) if you intend to relaunch without a reboot.
10.	Verify IB is actually in use — with NCCL silently falling back to TCP everything
11.	still works, just slower. Aggregate throughput is the honest check.
Credits
⁃	tonyd2wild — the recipe this reproduces
⁃	(GLM-5.2-QuantTrio-200K-4x-DGX-Spark).
⁃	QuantTrio — the Int4-Int8Mix checkpoint (unpruned).
⁃	CosmicRaisins — the sm12x Triton kernel set.
⁃	eugr (Eugene Rakhmatulin) — spark-vllm-docker cluster tooling.
⁃	Zhipu AI — GLM-5.2 (check the model license for your use case).
⁃	The vLLM project.
4 consumer GB10 boxes, an unpruned 744B-class MoE at 200K context, 52 tok/s aggregate —
and the one lesson we’d underline for anyone using pin-and-merge build systems: your pin
is only as pinned as the branches you merge into it.
The c4 numbers show useful aggregate throughput, but agent traffic is rarely uniform. Before an OOM or obvious slowdown, what tells you that concurrency is already harming a long coding or tool-calling task: acceptance rate, repeated tool calls, time-to-first-token variance, or a quality check in the harness?
Good question — we measured this on our side and the answer surprised us.
For agent traffic, per-stream decode tok/s is a poor early indicator. On a real
my app (almost MCP tools fully) run against our 4×Spark GLM-5.2 we logged 3.2M prompt tokens
against 16.6K generated — a 192:1 prefill:decode ratio. The tool schemas plus the
growing conversation dominate; decode is almost noise. So concurrency pressure
shows up as prefill queueing and TTFT variance long before decode rate moves.
Acceptance length turned out to be a bad concurrency signal specifically. Ours
swings widely with content at c=1 alone — templated output (SQL/JSON/counting)
sits near the ceiling, free prose drops by half. If you watch acceptance you end
up tracking the prompt mix, not the load.
What actually works for us, in order of usefulness:
  1. queue depth (num_requests_waiting) — the earliest honest signal
  2. generation-token flow, not completed-request count. We initially alerted on
    “no completions in N minutes” and it produced constant false positives: on a
    ~32 tok/s model with thinking enabled, one long request legitimately exceeds
    any threshold. Token flow is speed-independent — it only freezes when the
    engine actually wedges.
  3. per-request fixed KV cost. We probed ours with small requests and a delta
    method: cost is dominated by a fixed per-request term, nearly independent of
    prompt length. That sets a hard concurrency ceiling that context length barely
    changes — worth measuring on your setup, it is not the number the logs report.
One caveat on the last point: the logged “GPU KV cache size” is derived as
max_concurrency × max_model_len, so it is not comparable across different
max-model-len values. We wasted time on that before noticing.
What daily tasks do you perform with these 4 devices? Why is such a large context needed? Are you running multiple models, or a single large model?
