GLM-5.3-Flash on 2× DGX Spark — NVFP4 KV cache (288 B/token), 2.2M-token pool, 16-way serving, 900K context: full recipe
Setup: 2× DGX Spark (GB10, sm_121), CX7 200GbE direct link, TP=2. Model is the EXL3/TR3 4bpw encode (neko-legends/GLM-5.3-Flash-Uncensored-EXL3) running on the MiaAI-Lab EXL3 kit (vLLM fork) — full credit to them for the base stack. Vision tower loaded, tool calling working, OpenAI-compatible on :8888.
Honest numbers (llama-benchy + GSM8K, tables in the repo):
  │            metric            │                                  value                                   │
  │ KV pool                      │ 2,196,850 tokens (fits 8 full 262K sessions)                             │
  │ concurrency slots            │ 16        │
  │ max context                  │ 900K per request                                                         │
  │ prefill, single stream       │ ~680–705 tok/s, flat from 2K to 32K prompts, no depth degradation to 32K │
  │ decode, single stream        │ 20–24 tok/s (peak 27–29), no depth degradation                           │
  │ aggregate, steady mixed load │ 67.6 tok/s (GSM8K, 12-way)                                               │
  │ GSM8K under 12-way load      │ 59/60, zero request errors                                               │
What’s new: NVFP4 KV cache on the sparse-MLA path. The stock layout is 656 B/token (fp8_ds_mla); we store the latent as 288 B/token NVFP4 (packed e2m1 + per-16 e4m3 block scales). The prebuilt FlashInfer sparse-MLA kernel obviously can’t read NVFP4 — but it never has to: DSA only touches its top-k
selected rows, so a small Triton kernel gathers + dequantizes exactly those rows into a page-shaped fp8 scratch the kernel accepts (the 4×fp32 per-128-group scale words matched byte-for-byte against what concat_and_cache_mla writes). Cost: 0.36 ms/layer at decode, ≤5.6 ms/layer worst-case prefill.
Greedy outputs come out byte-identical to fp8 KV on our probes; GSM8K is at parity. ~2.3× pool density for ~3% overhead.
The part that will save you a power cycle: GB10’s unified memory livelocks instead of OOM-killing — the node stays pingable, ssh dies at banner exchange, and only the power button recovers it. The kernel stack (captured via py-spy/journalctl before one death) is the NVIDIA driver spinning in
try_to_free_pages with nothing reclaimable. Three host-side fixes turned this failure class into ordinary process restarts for us:
  1. zram swap (6G, prio 100) — the stock 16G file swap is too slow to absorb reclaim spikes; compressed RAM swap gives reclaim a real target
  2. A 0.2s-cadence memory watchdog that SIGTERMs vLLM below 0.75 GiB free (TERM first matters: raw SIGKILL mid-CUDA leaked ~20 GiB of driver memory that only returned after minutes of quiesce)
  3. vm.swappiness=180, vm.watermark_scale_factor=100 — and don’t go higher on the watermark: at 500 it walls ~12 GiB out of MemAvailable and looks exactly like a leak
Other traps documented in the repo’s troubleshooting table: the UMA startup free-memory check failing against page cache, MAX_MODEL_LEN reduction doubling per-token pool cost via hybrid block-id overhead, the fat-expert MoE fallback’s per-expert host syncs wedging the engine on 50–100K prompts (fix: the
kit’s GPU row-tiling, but only on a self-built image so Python and exllamav3_ext match), and a scheduler interleave policy we added so concurrent prefills don’t starve behind active decodes.
Known trade-offs, stated plainly: we run the model’s native MTP for speculation rather than DFlash2 — DFlash2 is ~5 tok/s faster on code but its ~10 GiB footprint is incompatible with the 2M+ pool on 121.63 GiB/node. And under simultaneous long-context arrivals, decoders run in waves (~50% duty, bursts
to 48–55 tok/s total) while the prefill backlog clears at ~585 tok/s — on one TP group sharing every cycle, the alternatives are prefill starvation or uniformly slow decode, so we took the waves.
Repo (MIT, everything included — patches, watchdog, dashboard, bench tables):
Credits: MiaAI-Lab (kit), turboderp (ExLlamaV3), neko-legends (encode), zai-org (model).
Fixed the token generation happening in waves with multiple requests, updated the repo
Updated repo with some fixes
Finding 1 — GPU util% lies on stall-bound steps. 96% utilization at 36W draw. Normal decode compute pulls 70W+ on these boards. If util is high and power is low, your SMs are parked on syncs, not working. Power draw is the honest signal.
Finding 2 — the real culprit: ~87 host round-trips per mixed step. py-spy from the host against the worker procs (the container lacks ptrace; sudo py-spy dump --nonblocking from outside works) showed every mixed decode+prefill step paying:
  • 45 MLA layers taking a torch.unique gather path (my NVFP4 code — dedup needs the row count on the host, so it syncs per layer)
  • 42 MoE layers hitting counts.max().item() because step tokens exceeded the EXL3 fused-MoE temp-rows cap (128)
Fix: extend the fixed-shape, no-dedup gather to the mixed-step ceiling (prefill chunk + max_seqs × spec slots = 192 tokens; duplicates cost ~2ms of bandwidth, the syncs cost ~700ms), and raise EXL3_TEMP_ROWS_FUSED to 192 (+8MB at MoE concurrency 6). Results, 5 streams decoding against a 40K cold
prefill:
│ metric │ before │ after │
│ mixed step time │ 830ms │ ~480ms │
│ aggregate decode │ ~10-13 tok/s │ ~24 tok/s │
│ concurrent prefill │ ~150 tok/s │ ~380 tok/s │
│ worst inter-token gap │ 1264ms │ ~570ms │
Finding 3 — three measurement traps that manufactured a fake mystery:
  1. iteration_tokens_total flushes at request completion (at least in this build). Per-step deltas showed my prefill getting zero tokens for 70 seconds, then 23K “at once” — I burned hours on a starvation theory before a scheduler-side probe proved chunks flowed steadily the whole time.
  2. Counting SSE chunks undercounts tok/s by ~τ under spec decode. Each stream chunk carries 2-3 accepted tokens. Chunk cadence measures step time (still useful!); token rate must come from engine counters or usage.
  3. Stale log tails: our launcher appends across boots, so failure-signature greps kept “detecting” the previous boot’s crash.
Finding 4 — MTP depth on this stack: 3, not 5. MTP-5 works on the NVFP4 stack posted here earlier, but if you run custom KV with CUDA-graph-captured gathers, watch your capture sizes: depth 5 × 16 seqs = 96-token steps, which fell off my 64-token graph-safe path and killed capture
(cudaErrorStreamCaptureInvalidated). Depth 3 × 16 = 64 exactly. Measured τ 2.87 vs 2.50 at depth 2, per-position acceptance 88.5/61.2/36.8% — position 3+ would free-ride, consistent with the acceptance data in tonyd2wild’s repo.
Much better multi-agent speeds and response times, updated repo
  │             scenario              │      session start       │           now           │
  │ 78K prompt re-submitted exactly   │ 22.7s (replay ~15K)      │ 0.3s (replay 7 tokens)  │
  │ 78K + 2K new (agent-turn shape)   │ 12.8s (replay ~8K)       │ 2.9s (replay 1.3K)      │
  │ c8 short-context aggregate        │ 53.4 tok/s, 385ms steps  │ 68.4 tok/s, 205ms steps │
  │ c5 decode during 40K cold prefill │ ~10–13 tok/s (yesterday) │ 20–23 tok/s             │
Have done a few more stability updates to the repo for multi agent workflows feeling a bit smoother. Also improved prefill quite a bit and am peaking at ~1600 tok/s prefill instead of the ~900 I was getting before. I’ve been using this daily for a few days in deepseek harness coding various projects and it really does feel like using opus 4.8, it’s so amazing we can run this in our homes.
whats the token gen speed?
decoding streams samples aggregate tok/s per stream draft acceptance accepted tokens/step
1 75,312 22.7 22.7 58% 2.75
2 12,306 35.5 17.7 58% 2.71
3 3,421 43.4 14.5 70% 2.41
4 2,321 41.2 10.3 71% 2.42
5 231 48.7 9.7 67% 2.33
6 54 55.7 9.3 65% 2.30
