GLM-5.2 (unpruned) at 800K max context on 4× DGX Spark 20-33 tok/s — NF3-hybrid checkpoint
So me and FABLE had a long night to some success off the shoulders of @CosmicRaisins and @Zatz hard work. We swapped models to get our KV POOL to 875k. I feel like it seems a little slower than what I was getting with the original 200k context and the 600k context version. Maybe there is some tuning but I wanted to atleast stand this up so if anyone wants to give it a shot they can getting speeds up.
We run a 4× DGX Spark cluster (GB10, 200GbE fabric) and have been following the GLM-5.2 work in the 4x GB10 cluster thread — everything below builds directly on the recipes from that thread.
Recently madeby561 published GLM-5.2-MXFP8-NVFP4-NF3-Hybrid: the unpruned model (all 256 experts) hybrid-quantized to 327GB — top-64 experts per layer in NVFP4, the rest in a custom 3-bit “NF3” format, MXFP8 elsewhere. It targets 4× RTX PRO 6000 (sm_120/amd64), but since it’s ~78GB smaller than the Int4-Int8Mix checkpoint most of us run, we wondered what the freed memory would do for KV on Sparks.
So we pointed the existing community recipes at it — b12x/eldritch stack rebuilt for sm_121a/aarch64, TP4 + DCP4 ag_rs with Zatz’s 640K launch settings as the template, MTP speculative decode. Result:
  • KV pool: 877,056 tokens, currently serving at --max-model-len 800000 — clean boot, coherent output, tool calling working
  • Decode at 800K max-len matches a 240K-max-len boot at equal fill (shallow-context bench; we haven’t run a depth sweep yet, so no claims about decode speed at 700K fill)
Since DCP trades speed for context (as CosmicRaisins’ DCP2 results showed), the repo keeps two launch shapes:
DCP4 “context” (800K max-len, 877K pool): c1 19.9 / c2 32.5 / c3 35.3 / c4 44.1 / c6 38.7 aggregate tok/s (512-tok gens, temp 0, MTP k=4, acceptance 3.2–3.7)
DCP1 “fast” (200K max-len, 219K pool): c1 24–29 (content-dependent, acceptance 3.3–4.0) / c4 54.2 / c6 67.4 aggregate
Port notes for anyone trying this checkpoint on GB10 (it needs madeby561’s custom serving stack): the NF3 CuteDSL kernel runs on sm_121a essentially as-is — it even ships an SM121 register-count table — but three things bit us: (1) the hybrid loader hardcodes its mxfp8_tier.json path to the author’s image layout (use the HYBRID_MXFP8_TIER_JSON env override), (2) warmup needs the patched b12x_sparse_indexer_warmup.py from the author’s docker image, which isn’t in any public repo yet, and (3) eugr-style aarch64 builds need nvidia-cutlass-dsl==4.5.2 plus its .pth path hook added.
Full replication recipe, both launch envs, and all fixes: GitHub - tonyd2wild/GLM-5.2-NF3-Hybrid-4x-DGX-Spark · GitHub
Credits: madeby561 for the NF3 format, kernel, and checkpoint — this is his work, we just ported it; lukealonso for b12x and the NVFP4 donor tier; Zatz for the DCP recipe our launch config is copied from; CosmicRaisins for the stack that got GLM-5.2 running on these boxes in the first place; m9e/eugr for the build harness; aidendle94 for pointing at the checkpoint. Happy to share anything else that’s useful, and very open to tuning suggestions — single-stream on the DCP4 shape (19.9) feels like it has headroom.
Awesome work! What’s the prefill speed like on this? Any improvements over the other recipe or is it slower?
Got this up and running - DC1 prefill was around 800 t/s.
