Hello!
Recently I met a problem with cuda (cuda-9.0).
My gpu is TITAN XP, and the driver is 387.84 for Linux. The OS is Centos 7.0.
I met the problem:
global function call is not configured" retured from ‘cublasCreate(&handle_)’
And the detail of the code is:
#include <unistd.h>
void CuDevice::FinalizeActiveGpu() {
// The device at this point should have active GPU, so we can query its name
// and memory stats and notify user which GPU is finally used.
// Get the device-id of active device:
int32 act_gpu_id;
int32 count;
cudaError_t e;
while (count < 3){
e = cudaGetDevice(&act_gpu_id);
KALDI_LOG << “while*******” << act_gpu_id;
if (e != cudaSuccess) {
sleep(10);
count++;
continue;
}else break;
if (count == 3) {
KALDI_CUDA_ERR(e, “Failed to get device-id of active device.”);
// Remember the id of active GPU
active_gpu_id_ = act_gpu_id; // CuDevice::Enabled() is true from now on
KALDI_LOG << “*******” << act_gpu_id;
// Initialize the CUBLAS
CU_SAFE_CALL(cublasCreate(&handle_));
// Notify user which GPU is finally used
char name[128];
DeviceGetName(name,128,act_gpu_id);
CU_SAFE_CALL(cudaGetDeviceProperties(&properties_, act_gpu_id));
KALDI_LOG << "The active GPU is [" << act_gpu_id << "]: " << name << "\t"
<< GetFreeMemory(&free_memory_at_startup_, NULL) << " version "
<< properties_.major << "." << properties_.minor;
return;
Could you please offer some help?
