e-con Systems has introduced e-CAM27_CUOAGX a 2MP MIPI CSI-2 global shutter RGB-IR camera for the NVIDIA® Jetson AGX Orin™ / AGX Xavier™ platform. It is a multi-camera solution that allows you to connect up to 6 cameras with a single NVIDIA® Jetson AGX Orin™ / AGX Xavier™ platform.
This camera is based on the 1/2.9" OV2312 global shutter CMOS Image sensor, and also comes with a fine-tuned image signal processor (ISP). Its ability to capture both RGB and IR images with one global shutter (GS) sensor reduces the number of cameras and hence the total system cost. This RGB-IR dual-mode camera can capture images and videos at high resolutions.
In addition, the IR feature helps to capture excellent images even at night or in zero light conditions. This camera also supports external triggers for multi-camera synchronization as well as synchronization with external sensors such as IMU, GPS, and LiDAR.
