e-con Systems’ e-CAM20_CUOAGX is a full HD MIPI CSI-2 global shutter camera for NVIDIA® Jetson AGX Orin™ platform. e-CAM20_CUOAGX is a multi-camera solution which allows to connect up to 6 cameras with the NVIDIA® Jetson AGX Orin™ platform.
e-CAM20_CUOAGX is based on 1/2.6" AR0234CS global shutter CMOS Image sensor with fine-tuned image signal processor (ISP). This Jetson Orin™ camera’s global shutter capability along with 120 fps frame rate help to minimize frame-to-frame distortion and reduce motion artifacts while capturing the scenes with lots of motion.
The high Signal to Noise Ratio(SNR) of this camera helps to capture excellent images even in low-light conditions. This camera supports external trigger for multi-camera synchronization as well as synchronization with external sensors.
Click here to download datasheet and other technical documents
Targeted Applications
- Autonomous Mobile Robots
- Warehouse Automation
- Robotic Arms
- Agriculture Vehicles
- Smart Traffic Management
