global variables not working?
I am experiencing a strange problems which seems really stupid as I am sure it has worked before. CUDA 2.3. See code below:
#include <cuda_runtime.h>
#pragma comment(lib, "cudart.lib")
__constant__ int* globalVar;
__global__ void runme(int *a) {
	a[0] = globalVar[0];
	a[1] = globalVar[1];
int main() {
	cudaError err;
	int a[2];
	int *test;
	err = cudaMalloc((void**)&test, sizeof(int) * 2);
	err = cudaMalloc((void**)&globalVar, sizeof(int) * 2);
	runme<<<1, 1>>>(test);
	err = cudaMemcpy(&a, globalVar, sizeof(int) * 2, cudaMemcpyDeviceToHost);
	return 0;
This code compiles and links fine, but fails to run, exiting with a kernel error. It seems I cannot access the ‘globalVar’ from within the kernel??
Changing the code to the following runs just fine:
__global__ void runme(int *a, const int *b) {
	a[0] = b[0];
	a[1] = b[1];
runme<<<1, 1>>>(test, globalVar);
So how does this work? Has CUDA 2.3 changed something?
You can’t dynamically allocate global variables in CUDA. I also very much doubt you can passed device pointers at runtime to global memory via the cudaMemcpyToSymbol() mechanism either, although I haven’t tried it.
