Gnome shell is filling up my logs at startup with segfaults although it seems to work flawlessly
nvidia-smi
Tue Mar 14 09:21:04 2023
| NVIDIA-SMI 530.30.02 Driver Version: 530.30.02 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3070 L… On | 00000000:01:00.0 Off | N/A |
| N/A 44C P8 18W / 115W| 841MiB / 8192MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3989 G /usr/lib/xorg/Xorg 447MiB |
| 0 N/A N/A 4237 G /usr/bin/gnome-shell 69MiB |
| 0 N/A N/A 4330 G /usr/libexec/mutter-x11-frames 34MiB |
| 0 N/A N/A 5409 G …enable-features=SystemNotifications 99MiB |
| 0 N/A N/A 5527 G …ures=SpareRendererForSitePerProcess 34MiB |
| 0 N/A N/A 7296 G gjs 72MiB |
| 0 N/A N/A 15124 C+G /usr/lib/vmware/bin/mksSandbox 70MiB |
| 0 N/A N/A 45372 G /usr/bin/gnome-control-center 9MiB |
Bug summary
[Tue Mar 14 08:57:39 2023] gnome-shell[3998]: segfault at 1 ip 00007f470e55c9ac sp 00007ffcd20ec9b0 error 4 in libnvidia-glcore.so.530.30.02[7f470d701000+25e4000] likely on CPU 12 (core 6, socket 0)
[Tue Mar 14 08:57:39 2023] Code: ef 5d e9 17 f5 1a 00 0f 1f 80 00 00 00 00 55 83 ff 0f 0f 87 8e 00 00 00 48 8b 05 57 86 95 01 48 8d 15 58 00 9f 01 64 48 8b 28 <0f> b6 46 01 44 8b 4c 82 34 0f b6 46 02 44 8b 44 82 34 0f b6 46 03
Steps to reproduce
  1. Step install debian 12
  2. Step install nvidia drivers version 530.30.02
  3. Step install gnome 44
  4. Step lauch dmesg -T
What happened
gnome shell is filling up my logs at startup with segfaults although it seems to work flawlessly
What did you expect to happen
I would like to see those segfaults disappear
Relevant logs, screenshots, screencasts etc.
I have filed a gnome shell bug upstream to the gnome-shell git and they told me to ask here
/label ~“1. Bug”
Does this also happen with a 525 driver, i.e. is a regression?
I don’t know I have this version 530.30.02
and after the last system update it gets even worse
the gnome desktop is now really acting up and shows a bit of unstability
[ 80.968447] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000038, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 81.219684] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.057309] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.100176] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.201619] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.274085] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.350786] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.431100] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.498692] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 84.575276] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 86.360978] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 91.975616] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 92.114503] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE CE0 HUBCLIENT_CE1 faulted @ 0x1_02ba0000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 92.224873] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 92.345609] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_1 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 94.244806] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 94.368531] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 99.468567] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 143.821419] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 148.895471] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 153.997716] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 154.051575] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 154.123026] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 154.217133] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000040, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x0_04942000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 155.827175] device enp2s0 left promiscuous mode
[ 155.827808] bridge-enp2s0: disabled promiscuous mode
[ 175.177522] kvm: SMP vm created on host with unstable TSC; guest TSC will not be reliable
[ 175.898541] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 181.424127] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 308.840470] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 325.804872] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 325.876041] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 326.001070] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 326.108610] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 332.289668] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 332.390107] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 332.485396] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 336.678627] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 344.377944] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x0_04948000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 344.440119] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 344.587527] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 353.215188] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 353.286483] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 353.416710] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 353.499955] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 355.013147] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 360.316685] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 360.416821] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 360.513447] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04940000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 671.361624] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 676.377480] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 676.500945] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 676.549538] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04940000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 676.647218] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 774.496132] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 779.114678] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 784.186988] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 791.243899] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 791.346877] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 791.449499] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 791.545974] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04940000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 856.460664] umip: pillbox[53790] ip:556ab277d32d sp:7ffe36756870: SIDT instruction cannot be used by applications.
[ 856.460669] umip: pillbox[53790] ip:556ab277d32d sp:7ffe36756870: For now, expensive software emulation returns the result.
[ 856.460671] umip: pillbox[53790] ip:556ab277d34d sp:7ffe36756870: SIDT instruction cannot be used by applications.
[ 856.460672] umip: pillbox[53790] ip:556ab277d34d sp:7ffe36756870: For now, expensive software emulation returns the result.
[ 856.460674] umip: pillbox[53790] ip:556ab277d3dd sp:7ffe36756870: SGDT instruction cannot be used by applications.
[ 881.263123] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 881.435245] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04940000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 885.091435] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.144432] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.204482] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.270269] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.384748] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.461636] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x0_04942000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 890.923019] device enp2s0 entered promiscuous mode
[ 890.923648] bridge-enp2s0: enabled promiscuous mode
[ 898.612761] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 0, TPC 0, SM 1): MMU NACK Errors
[ 898.612895] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 0, TPC 0, SM 1): Multiple Warp Errors
[ 898.613020] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x5047b0=0xb030020 0x5047b4=0x4 0x5047a8=0xe812b60 0x5047ac=0x1174
[ 898.613243] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 0, TPC 1, SM 0): MMU NACK Errors
[ 898.613370] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 0, TPC 1, SM 0): Multiple Warp Errors
[ 898.613495] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x504f30=0xb010020 0x504f34=0x4 0x504f28=0xe812b60 0x504f2c=0x1174
[ 898.613719] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 0, TPC 2, SM 1): MMU NACK Errors
[ 898.613846] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x5057b0=0xb020020 0x5057b4=0x0 0x5057a8=0xe812b60 0x5057ac=0x1174
[ 898.614075] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 1, TPC 0, SM 1): MMU NACK Errors
[ 898.614203] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 1, TPC 0, SM 1): Multiple Warp Errors
[ 898.614330] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x50c7b0=0xb000020 0x50c7b4=0x4 0x50c7a8=0xe812b60 0x50c7ac=0x1174
[ 898.614575] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 1, TPC 2, SM 1): MMU NACK Errors
[ 898.614701] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x50d7b0=0xb000020 0x50d7b4=0x0 0x50d7a8=0xe812b60 0x50d7ac=0x1174
[ 898.614929] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 2, TPC 0, SM 1): MMU NACK Errors
[ 898.615057] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 2, TPC 0, SM 1): Multiple Warp Errors
[ 898.615181] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x5147b0=0xb010020 0x5147b4=0x4 0x5147a8=0xe812b60 0x5147ac=0x1174
[ 898.615408] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 2, TPC 2, SM 1): MMU NACK Errors
[ 898.615538] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 2, TPC 2, SM 1): Multiple Warp Errors
[ 898.615662] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x5157b0=0xb000020 0x5157b4=0x4 0x5157a8=0xe812b60 0x5157ac=0x1174
[ 898.615889] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 3, TPC 0, SM 0): MMU NACK Errors
[ 898.616019] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 3, TPC 0, SM 0): Multiple Warp Errors
[ 898.616144] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x51c730=0xb010020 0x51c734=0x4 0x51c728=0xe812b60 0x51c72c=0x1174
[ 898.616368] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 4, TPC 1, SM 1): MMU NACK Errors
[ 898.616495] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x524fb0=0xb030020 0x524fb4=0x0 0x524fa8=0xe812b60 0x524fac=0x1174
[ 898.616703] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 4, TPC 3, SM 0): MMU NACK Errors
[ 898.616831] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 4, TPC 3, SM 0): Multiple Warp Errors
[ 898.616956] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x525f30=0xb010020 0x525f34=0x4 0x525f28=0xe812b60 0x525f2c=0x1174
[ 898.617177] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 5, TPC 2, SM 1): MMU NACK Errors
[ 898.617309] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 5, TPC 2, SM 1): Multiple Warp Errors
[ 898.617434] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x52d7b0=0xb010020 0x52d7b4=0x4 0x52d7a8=0xe812b60 0x52d7ac=0x1174
[ 898.617651] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Warp Exception on (GPC 5, TPC 3, SM 1): MMU NACK Errors
[ 898.617783] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics SM Global Exception on (GPC 5, TPC 3, SM 1): Multiple Warp Errors
[ 898.617912] NVRM: Xid (PCI:0000:01:00): 13, pid=‘’, name=, Graphics Exception: ESR 0x52dfb0=0xb000020 0x52dfb4=0x4 0x52dfa8=0xe812b60 0x52dfac=0x1174
[ 898.629912] NVRM: Xid (PCI:0000:01:00): 13, pid=4746, name=mutter-x11-fram, Graphics Exception: ChID 0008, Class 0000c797, Offset 00000000, Data 00000000
[ 898.640050] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 904.568764] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 904.663659] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 904.724695] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 906.536944] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 907.380111] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 907.535858] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 907.636205] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 910.715167] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x1_02ba0000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.708639] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.742564] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.789154] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.817526] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.865548] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.916048] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 911.971963] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 912.041557] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 912.089906] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 912.119736] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 912.195132] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x1_02ba1000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 995.218129] umip_printk: 7 callbacks suppressed
[ 995.218131] umip: pillbox[61639] ip:5621d06e932d sp:7fffa0b49f40: SIDT instruction cannot be used by applications.
[ 995.218135] umip: pillbox[61639] ip:5621d06e932d sp:7fffa0b49f40: For now, expensive software emulation returns the result.
[ 995.218138] umip: pillbox[61639] ip:5621d06e934d sp:7fffa0b49f40: SIDT instruction cannot be used by applications.
[ 995.218138] umip: pillbox[61639] ip:5621d06e934d sp:7fffa0b49f40: For now, expensive software emulation returns the result.
[ 995.218140] umip: pillbox[61639] ip:5621d06e93dd sp:7fffa0b49f40: SGDT instruction cannot be used by applications.
[ 1024.912387] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1031.848022] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_0 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1031.956888] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1032.006244] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.078613] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.181256] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.305744] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.429549] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.554938] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_1 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.681887] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_1 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.780243] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1036.862353] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1041.954168] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1051.623092] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1051.731717] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1053.181825] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1053.306591] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1053.392924] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1147.818971] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_1 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1147.943780] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04942000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1148.101522] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1148.144252] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1150.379152] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1150.480726] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1150.627052] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1156.119545] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04948000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1156.202234] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04944000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1162.002750] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1164.664095] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_5 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1164.707806] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04940000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1164.827655] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1164.911577] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1165.008985] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_3 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1176.340556] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1176.447498] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1176.480140] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1176.514794] NVRM: Xid (PCI:0000:01:00): 31, pid=4746, name=mutter-x11-fram, Ch 00000008, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_4 faulted @ 0x0_04946000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
[ 1461.091669] nvidia 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000b address=0x50505057f200 flags=0x0010]
[ 1521.204010] nvidia 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000b address=0x50505057f200 flags=0x0010]
[ 1581.324429] NVRM: Xid (PCI:0000:01:00): 31, pid=57485, name=main-mks, Ch 00000046, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x0_0791d000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
This rather looks like your gpu is faulty. Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (664.7 KB)
this seems related Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ kernel problem or driver issue? - #2 by Robert_Crovella
downgrading a bit …
apt-get full-upgrade
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Calculating upgrade… Done
The following NEW packages will be installed:
libcuda1-i386:i386 libnvidia-nvvm4:i386 libnvidia-wayland-client nvidia-driver-libs-i386:i386
The following packages will be DOWNGRADED:
libcuda1 libcuda1:i386 libegl-nvidia0 libegl-nvidia0:i386 libgl1-nvidia-glvnd-glx
libgl1-nvidia-glvnd-glx:i386 libgles-nvidia1 libgles-nvidia1:i386 libgles-nvidia2 libgles-nvidia2:i386
libglx-nvidia0 libglx-nvidia0:i386 libnvcuvid1 libnvcuvid1:i386 libnvidia-allocator1
libnvidia-allocator1:i386 libnvidia-cfg1 libnvidia-compiler libnvidia-eglcore libnvidia-eglcore:i386
libnvidia-encode1 libnvidia-encode1:i386 libnvidia-fbc1 libnvidia-glcore libnvidia-glcore:i386
libnvidia-glvkspirv libnvidia-glvkspirv:i386 libnvidia-ml1 libnvidia-nvvm4 libnvidia-opticalflow1
libnvidia-ptxjitcompiler1 libnvidia-ptxjitcompiler1:i386 libnvidia-rtcore libnvoptix1
nvidia-alternative nvidia-detect nvidia-driver nvidia-driver-bin nvidia-driver-libs
nvidia-driver-libs:i386 nvidia-egl-common nvidia-egl-icd nvidia-egl-icd:i386 nvidia-kernel-dkms
nvidia-kernel-support nvidia-legacy-check nvidia-libopencl1 nvidia-opencl-common nvidia-opencl-icd
nvidia-smi nvidia-vdpau-driver nvidia-vulkan-common nvidia-vulkan-icd nvidia-vulkan-icd:i386
xserver-xorg-video-nvidia
0 upgraded, 4 newly installed, 55 downgraded, 0 to remove and 0 not upgraded.
Need to get 400 MB of archives.
After this operation, 169 MB of additional disk space will be used.
now it seems better… no more it’s faulty messages also purged docker
nvidia-smi
Wed Mar 15 12:42:53 2023
| | | MIG M. |
| N/A 41C P8 18W / 115W| 882MiB / 8192MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 4203 G /usr/lib/xorg/Xorg 381MiB |
| 0 N/A N/A 4451 G /usr/bin/gnome-shell 257MiB |
| 0 N/A N/A 4544 G /usr/libexec/mutter-x11-frames 7MiB |
| 0 N/A N/A 5062 G /usr/bin/gnome-control-center 8MiB |
| 0 N/A N/A 5063 G /usr/bin/nautilus 17MiB |
| 0 N/A N/A 5078 G /usr/bin/deja-dup 7MiB |
| 0 N/A N/A 5634 G …enable-features=SystemNotifications 38MiB |
| 0 N/A N/A 5716 G …ures=SpareRendererForSitePerProcess 34MiB |
| 0 N/A N/A 7788 G gjs 60MiB |
| 0 N/A N/A 10154 C+G /usr/lib/vmware/bin/mksSandbox 63MiB |
I am still getting this message tho
[Wed Mar 15 12:41:32 2023] show_signal_msg: 27 callbacks suppressed
[Wed Mar 15 12:41:32 2023] gnome-shell[4212]: segfault at 1 ip 00007f07bdd5c9ac sp 00007ffcc2ab3c50 error 4 in libnvidia-glcore.so.530.30.02[7f07bcf01000+25e4000] likely on CPU 0 (core 0, socket 0)
[Wed Mar 15 12:41:32 2023] Code: ef 5d e9 17 f5 1a 00 0f 1f 80 00 00 00 00 55 83 ff 0f 0f 87 8e 00 00 00 48 8b 05 57 86 95 01 48 8d 15 58 00 9f 01 64 48 8b 28 <0f> b6 46 01 44 8b 4c 82 34 0f b6 46 02 44 8b 44 82 34 0f b6 46 03
nvidia-bug-report.log.gz (649.5 KB)
I am attaching the new bugreport (after the downgrade)
root@ghost:~# lsmod|grep nouveau
root@ghost:~#
I don’t know what has been downgraded, the driver is always the same.
the system downgraded the libraries. The bug is not related to the driver it is related to the libraries and how gnome uses those
I have installed acpid so we can have more info
gnome seems to dislike those settings gdm3 doesn’t start at all if I enable acpi with :
Option “ConnectToAcpid” “1”
Option “AcpidSocketPath” “/var/run/acpid.socket”
root@ghost:~#
root@ghost:~#
root@ghost:~#
root@ghost:~#
root@ghost:~# ls /var/run/acpid.socket
root@ghost:~# ls -lart /var/run/acpid.socket
srw-rw-rw- 1 root root 0 Mar 15 15:27 /var/run/acpid.socket
root@ghost:~#
