GPG Keyring error - DGX OS 5
Recently got DGX OS upgraded to DGX OS 5. Tried running sudo apt-get update and getting the below error:
adminuser2@dgxserver2:~$ sudo apt-get update
Hit:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64  InRelease
Get:2 https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal InRelease [15.5 kB]
Get:3 https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal-updates InRelease [15.7 kB]
Err:2 https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 208CE844D9F220AD
Err:3 https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal-updates InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:5 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Reading package lists... Done
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/cuda-compute-repo.list:1 and /etc/apt/sources.list.d/cuda-ubuntu2004-x86_64.list:1
W: Target Translations (en_IN) is configured multiple times in /etc/apt/sources.list.d/cuda-compute-repo.list:1 and /etc/apt/sources.list.d/cuda-ubuntu2004-x86_64.list:1
W: Target Translations (en) is configured multiple times in /etc/apt/sources.list.d/cuda-compute-repo.list:1 and /etc/apt/sources.list.d/cuda-ubuntu2004-x86_64.list:1
W: GPG error: https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 208CE844D9F220AD
E: The repository 'https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 208CE844D9F220AD
E: The repository 'https://repo.download.nvidia.com/baseos/ubuntu/focal/x86_64 focal-updates InRelease' is not signed.
I have tried deleting and upgrading key, but get this error:
adminuser2@dgxserver2:~$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 208CE844D9F220AD
Executing: /tmp/apt-key-gpghome.ToLR3OkPJK/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 208CE844D9F220AD
gpg: keyserver receive failed: No data
Kindly help : )
Please try the following instructions for rotating/updating the GPG keys on DGX.
Tried the steps, but now getting the below error:
coeanalytics2@dgxserver2:~$ sudo apt-get update
E: Conflicting values set for option Signed-By regarding source https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/ /: /usr/share/keyrings/cuda_debian_prod.gpg != /usr/share/keyrings/cuda-archive-keyring.gpg
E: The list of sources could not be read.
Try moving those files: “/usr/share/keyrings/cuda_debian_prod.gpg” and “/usr/share/keyrings/cuda-archive-keyring.gpg” somewhere else (i.e. some temp folder in your home dir). Then repeat instructions for rotating the GPG key.
Rotating the GPG Key link.
I’m having this same issue with the same system/OS. However moving the files and starting over doesn’t resolving the issue and I still see the same error:
E: Conflicting values set for option Signed-By regarding source Index of /compute/cuda/repos/ubuntu2004/x86_64 /: /usr/share/keyrings/cuda_debian_prod.gpg != /usr/share/keyrings/cuda-archive-keyring.gpg
Disregard. Found solution that works for our system:
" Also check for and remove cuda*.list files under the /etc/apt/sources.d/ directory."
from here: https://developer.nvidia.com/blog/updating-the-cuda-linux-gpg-repository-key/
