thanks for your answer. I put high/low signal to the input by directly connecting a cable to 3,3V/GND. So pull down strength shouldn’t be an issue.
Directly after system startup:
echo 38 > /sys/class/gpio/export
sudo cat /sys/kernel/debug/gpio
State is always shown as low independent of actual pin state.
gpiochip0: GPIOs 0-255, parent: platform/6000d000.gpio, tegra-gpio:
gpio-0 ( )
gpio-1 ( )
gpio-2 ( |pcie_wake ) in hi
gpio-3 ( )
gpio-4 ( )
gpio-5 ( )
gpio-6 ( |system-suspend-gpio ) out hi
gpio-7 ( )
gpio-8 ( )
gpio-9 ( )
gpio-10 ( )
gpio-11 ( )
gpio-12 (SPI1_MOSI )
gpio-13 (SPI1_MISO )
gpio-14 (SPI1_SCK )
gpio-15 (SPI1_CS0 )
gpio-16 (SPI0_MOSI )
gpio-17 (SPI0_MISO )
gpio-18 (SPI0_SCK )
gpio-19 (SPI0_CS0 )
gpio-20 (SPI0_CS1 )
gpio-21 ( )
gpio-22 ( )
gpio-23 ( )
gpio-24 ( )
gpio-25 ( )
gpio-26 ( )
gpio-27 ( )
gpio-28 ( )
gpio-29 ( )
gpio-30 ( )
gpio-31 ( )
gpio-32 ( )
gpio-33 ( )
gpio-34 ( )
gpio-35 ( )
gpio-36 ( )
gpio-37 ( )
gpio-38 (GPIO13 |sysfs ) in lo
After setting the direction to input again:
echo in > /sys/class/gpio/gpio38/direction
Input is put to low state:
gpio-0 ( )
gpio-1 ( )
gpio-3 ( )
gpio-4 ( )
gpio-5 ( )
gpio-7 ( )
gpio-8 ( )
gpio-9 ( )
gpio-10 ( )
gpio-11 ( )
gpio-14 (SPI1_SCK )
gpio-15 (SPI1_CS0 )
gpio-18 (SPI0_SCK )
gpio-19 (SPI0_CS0 )
gpio-20 (SPI0_CS1 )
gpio-21 ( )
gpio-22 ( )
gpio-23 ( )
gpio-24 ( )
gpio-25 ( )
gpio-26 ( )
gpio-27 ( )
gpio-28 ( )
gpio-29 ( )
gpio-30 ( )
gpio-31 ( )
gpio-32 ( )
gpio-33 ( )
gpio-34 ( )
gpio-35 ( )
gpio-36 ( )
gpio-37 ( )
Input is put to high state:
gpio-0 ( )
gpio-1 ( )
gpio-3 ( )
gpio-4 ( )
gpio-5 ( )
gpio-7 ( )
gpio-8 ( )
gpio-9 ( )
gpio-10 ( )
gpio-11 ( )
gpio-14 (SPI1_SCK )
gpio-15 (SPI1_CS0 )
gpio-18 (SPI0_SCK )
gpio-19 (SPI0_CS0 )
gpio-20 (SPI0_CS1 )
gpio-21 ( )
gpio-22 ( )
gpio-23 ( )
gpio-24 ( )
gpio-25 ( )
gpio-26 ( )
gpio-27 ( )
gpio-28 ( )
gpio-29 ( )
gpio-30 ( )
gpio-31 ( )
gpio-32 ( )
gpio-33 ( )
gpio-34 ( )
gpio-35 ( )
gpio-36 ( )
gpio-37 ( )
gpio-38 (GPIO13 |sysfs ) in hi
I also don’t get any registerred interrupts from that pin until I set the direction to input again. I tried it with another pin and it has the same behaviour. I also used the default dtsi files generated by pinmux excel sheet, but there was no change. It seems as if the state of the pin is disconnected from the internal logic until I set it as input per command.
I did some changes in other device tree files. But I cannot imagine that it has something to do with those changes.
In file …/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi:
Commented out the following lines:
//#include “porg-platforms/tegra210-porg-camera-rbpcv2-imx219.dtsi”
//#include “porg-platforms/tegra210-porg-camera-rbpcv2-dual-imx219.dtsi”
//#include “porg-plugin-manager/tegra210-porg-plugin-manager.dtsi”
In file …/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts:
Added the following line:
#include “tegra210-porg-p3448-common.dtsi”
#include “tegra210-tc358743.dtsi”
#include “porg-platforms/tegra210-porg-pinmux-p3448-0000-a02.dtsi”
#include “porg-platforms/tegra210-porg-gpio-p3448-0000-a02.dtsi”
