We are searching for a GPU benchmarking tool for the Jetson AGX Xavier to stress the GPU. Ideally, the benchmark shouldn’t require a display. Does such a benchmarking tool exist for the Jetson AGX Xavier?
You can try glmark2:
OpenGL issue after install nvidia-jetpack via apt-get - #5 by DaneLLL
Or can run cuBLAS sample. You can run the default sample. Or furthermore try this patch:
Jetson/L4T/TRT Customized Example - eLinux.org
