I have a RTX 3080 display card. I installed the nvhpc-22.5 in Centos 8 stream. I am testing it with the saxpy.f90. It compiles fine with no errors, but when I run it give me errors. see below. I have no clues as what to do next. Any suggestion is appreciated. Thank you!
$ nvfortran -stdpar=gpu -Minfo saxpy.f90 -o saxpy -cudaforlibs
saxpy_concurrent:
26, Generating NVIDIA GPU code
26, Loop parallelized across CUDA thread blocks, CUDA threads(128) blockidx%x threadidx%x
saxpy_do:
36, FMA (fused multiply-add) instruction(s) generated
$ ./saxpy
Current file: /home/jluo/saxpy.f90
function: saxpy_concurrent
line: 26
This file was compiled: -acc=gpu -gpu=cc35 -gpu=cc50 -gpu=cc60 -gpu=cc60 -gpu=cc70 -gpu=cc75 -gpu=cc80 -
Hi Matt, You are right. It can not find the GPU. I have cuda 11.7. Also, I have set the LD_LIBRARY_PATH. See below. Thank you!
$ nvaccelinfo -v
libcuda.so not found
No accelerators found.
Check that you have installed the CUDA driver properly
Check that your LD_LIBRARY_PATH environment variable points to the CUDA runtime installation directory
$ echo $LD_LIBRARY_PATH
/usr/local/lib:/opt/nvidia/hpc_sdk/Linux_x86_64/22.5/cuda/11.7/targets/x86_64-linux/lib/stabs:/opt/nvidia/hpc_sdk/Linux_x86_64/22.5/REDIST/cuda/11.7/targets/x86_64-linux/lib/stabs
While I don’t know for sure, I’m guessing you have Nouveau graphics driver installed, which doesn’t support CUDA. The CUDA driver (i.e. libcuda.so) is not included with the NV HPC SDK and must be installed separately (this is why setting the LD_LIBRARY_PATH isn’t working).
