Hi everyone,
I’m dealing with the compilation of a post processing code written in fortran 90 (MPI with OpenACC acceleration) with mpif90 under nvhpc-23.1 on the CINECA Italian cluster named “Leonardo”. Actually, when I compile the code with:
mpif90 -acc=gpu -target=gpu -gpu=cc80 -o post_code_name “objects list” -fortranlibs -cudalib -acclibs
I obtain the following:
/usr/bin/ld: impossibile trovare -lcusolverMp
/usr/bin/ld: impossibile trovare -lcal
/usr/bin/ld: impossibile trovare -lcutensor
/usr/bin/ld: impossibile trovare -lcutensorMg
/usr/bin/ld: impossibile trovare -lnccl
/usr/bin/ld: impossibile trovare -lnvshmem_device
/usr/bin/ld: impossibile trovare -lnvshmem_host
pgacclnk: child process exit status 1: /usr/bin/ld
For the sake of clarity the module I loaded in the Leonardo cluster are:
1) profile/base
2) nvhpc/23.1
3) zlib/1.2.13--gcc--11.3.0
4) openmpi/4.1.4--nvhpc--23.1-cuda-11.8
5) cuda/11.8
However, when I compile the same code with my local cluster under nvhpc-24.1 I successfully obtain the final code without error. Unfortunately, on the Leonardo cluster nvhpc-24.1 is not installed.
Again, for the sake of clarity the module I loaded in my local cluster are:
1) base
2) gcc/gcc(default)
3) pgi/pgi_20.4
4) intel/intel20(default)
5) lsf10.1
6) pfs
7) nvhpc-22.3
Any suggestion about this little issue? Thanks in advance,
-Matteo
