GPU memory is empty, but CUDA out of memory error occurs
During training this code with ray tune (1 gpu for 1 trial), after few hours
of training (about 20 trials) CUDA out of memory error occurred from GPU:0,1. And even after terminated the training process, the GPUS still give out of memory error.
nvidia-smi result
As above, currently, all of my GPU devices are empty. And there is no other python process running except these two.
import torch
torch.rand(1, 2).to('cuda:0') # cuda out of memory error
torch.rand(1, 2).to('cuda:1') # cuda out of memory error
torch.rand(1, 2).to('cuda:2') # working
torch.rand(1, 2).to('cuda:3') # working
torch.cuda.device_count() # 4
torch.cuda.memory_reserved() # 0
torch.cuda.is_available() # True
# error message of GPU 0, 1
RuntimeError: CUDA error: out of memory
However, GPU:0,1 give out of memory errors. If I reboot the computer(ubunutu 18.04.3), it returns to normal, but if I train the code again, the same problem occurs.
  • numba and tensorflow have same problem, so it seems like it is not because of pytorch.
>>> from numba import cuda
>>> device = cuda.get_current_device()
  File "<stdin>", line 1, in <module>
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/api.py", line 460, in get_current_device
    return current_context().device
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/devices.py", line 212, in get_context
    return _runtime.get_or_create_context(devnum)
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/devices.py", line 138, in get_or_create_context
    return self._get_or_create_context_uncached(devnum)
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/devices.py", line 153, in _get_or_create_context_uncached
    return self._activate_context_for(0)
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/devices.py", line 169, in _activate_context_for
    newctx = gpu.get_primary_context()
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/driver.py", line 542, in get_primary_context
    driver.cuDevicePrimaryCtxRetain(byref(hctx), self.id)
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/driver.py", line 302, in safe_cuda_api_call
    self._check_error(fname, retcode)
  File "/home/user_name/.pyenv/versions/tensorflow/lib/python3.8/site-packages/numba/cuda/cudadrv/driver.py", line 342, in _check_error
    raise CudaAPIError(retcode, msg)
numba.cuda.cudadrv.driver.CudaAPIError: [2] Call to cuDevicePrimaryCtxRetain results in CUDA_ERROR_OUT_OF_MEMORY
  • dmesg result. (No GPU has fallen off the bus error)
dmesg | grep -i -e nvidia -e nvrm
[    5.946174] nvidia: loading out-of-tree module taints kernel.
[    5.946181] nvidia: module license 'NVIDIA' taints kernel.
[    5.956595] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    5.968280] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[    5.970485] nvidia 0000:09:00.0: enabling device (0000 -> 0003)
[    5.970571] nvidia 0000:09:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    6.015145] nvidia 0000:0a:00.0: enabling device (0000 -> 0003)
[    6.015394] nvidia 0000:0a:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    6.064993] nvidia 0000:42:00.0: enabling device (0000 -> 0003)
[    6.065072] nvidia 0000:42:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    6.115778] nvidia 0000:43:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    6.164680] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.27.04  Fri Dec 11 23:35:05 UTC 2020
[    6.174137] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  460.27.04  Fri Dec 11 23:24:19 UTC 2020
[    6.176472] [drm] [nvidia-drm] [GPU ID 0x00000900] Loading driver
[    6.176567] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:09:00.0 on minor 0
[    6.176635] [drm] [nvidia-drm] [GPU ID 0x00000a00] Loading driver
[    6.176636] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:0a:00.0 on minor 1
[    6.176709] [drm] [nvidia-drm] [GPU ID 0x00004200] Loading driver
[    6.176710] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:42:00.0 on minor 2
[    6.176760] [drm] [nvidia-drm] [GPU ID 0x00004300] Loading driver
[    6.176761] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:43:00.0 on minor 3
[    6.189768] nvidia-uvm: Loaded the UVM driver, major device number 511.
[    6.744582] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:40/0000:40:03.1/0000:43:00.1/sound/card4/input12
[    6.744664] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:40/0000:40:03.1/0000:43:00.1/sound/card4/input15
[    6.744755] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:40/0000:40:03.1/0000:43:00.1/sound/card4/input17
[    6.744852] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:40/0000:40:03.1/0000:43:00.1/sound/card4/input19
[    6.744952] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:40/0000:40:01.3/0000:42:00.1/sound/card3/input11
[    6.745301] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:40/0000:40:01.3/0000:42:00.1/sound/card3/input16
[    6.745739] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:40/0000:40:01.3/0000:42:00.1/sound/card3/input18
[    6.746280] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:40/0000:40:01.3/0000:42:00.1/sound/card3/input20
[    7.117377] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.3/0000:09:00.1/sound/card0/input9
[    7.117453] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.3/0000:09:00.1/sound/card0/input10
[    7.117505] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.3/0000:09:00.1/sound/card0/input13
[    7.117559] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.3/0000:09:00.1/sound/card0/input14
[    7.117591] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input21
[    7.117650] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input22
[    7.117683] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input23
[    7.117720] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input24
[    9.462521] caller os_map_kernel_space.part.8+0x74/0x90 [nvidia] mapping multiple BARs
How can I debug this problem, or resolve it without rebooting?
setting
  • ubuntu 18.04.3
  • RTX 2080ti
  • CUDA version 10.2
  • nvidia driver version: 460.27.04
  • cudnn 7.6.4.38
  • Python 3.8.4
  • pytorch 1.7.0, 1.9.0, 1.9.0+cu111
  • cpu: (AMD Ryzen Threadripper 2950X 16-Core Processor)x32
  • memory: 125G
  • power: 2000W
We are having what appears to be the same issue with RTX 2080 Ti GPUs on our HPC cluster. We have found we can recover them by running nvidia-smi --gpu-reset -i $n where $n is the id of the GPU returning the OOM message. This avoids having to reboot the host, but we are still searching for the underlying cause.
Thanks for the comment!
Fortunately, it seems like the issue is not happening after upgrading pytorch version to 1.9.1+cu111.
I will try --gpu-reset if the problem occurs again. Thanks for your help.
Thank you also! We will try upgrading pytorch to the same version to see if it prevents the GPUs from entering the unusable state.
Do you have any ideas to solve this problem now? I got the same issue. If my memory is correct, “GPU memory is empty, but CUDA out of memory” occurred after I killed the process with P-ID.
Reduce batch size
