Dear Forums,
I am trying to run CUDA on a headless RHEL 5.2 server box. It has a built-in ATI video card, and I have added a Quadro FX-4600 PCI-X board for CUDA. There is no X server running (and I prefer it that way).
I have downloaded and installed the driver, toolkit, and SDK that form the CUDA 2.0 release. When I run deviceQuery, things look good:
[codebox][root@ca3-1 release]# ./deviceQuery
There is 1 device supporting CUDA
Device 0: “Quadro FX 4600”
Major revision number: 1
Minor revision number: 0
Total amount of global memory: 805044224 bytes
Number of multiprocessors: 12
Number of cores: 96
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.19 GHz
Concurrent copy and execution: No
Test PASSED
Press ENTER to exit…
[/codebox]
But when I run the other examples, they either fail or segfault, e.g.:
[codebox][root@ca3-1 release]# ./eigenvalues
Using device 0: Quadro FX 4600
Matrix size: 2048 x 2048
Precision: 0.000010
Iterations to be timed: 100
Result filename: ‘eigenvalues.dat’
Gerschgorin interval: -2.894310 / 2.923303
Average time step 1: 224.800690 ms
Average time step 2, one intervals: 224.823013 ms
Average time step 2, mult intervals: 112.424240 ms
Average time TOTAL: 786.905884 ms
Segmentation fault
[root@ca3-1 release]# ./BlackScholes
Initializing data…
…allocating CPU memory for options.
…allocating GPU memory for options.
…generating input data in CPU mem.
…copying input data to GPU mem.
Data init done.
Executing Black-Scholes GPU kernel (512 iterations)…
Options count : 8000000
BlackScholesGPU() time : 111.513420 msec
Effective memory bandwidth: 0.717402 GB/s
Gigaoptions per second : 0.071740
Reading back GPU results…
Checking the results…
…running CPU calculations.
Comparing the results…
L1 norm: 1.000000E+00
Max absolute error: 9.574021E+01
TEST FAILED
Shutting down…
…releasing GPU memory.
…releasing CPU memory.
Shutdown done.
[/codebox]
One thing that caught my eye is that if I run glxinfo, it looks like the ATI OpenGL is running. Shouldn’t it be NVIDIA?
[codebox][root@ca3-1 release]# glxinfo | egrep -e ‘(client|server|OpenGL)’
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Radeon 9200 OpenGL Engine
OpenGL version string: 1.3 ATI-1.5.36
OpenGL extensions:[/codebox]
Any help debugging from here would be hugely appreciated.
