GPU productivity can not be restored after limiting tdp via nvidia-smi
I limited TDP of my GPU using command:
nvidia-smi -pl 100.
After that i can not restore the productivity of my GPU using commands:
nvidia-smi -pl 200;
nvidia-smi -rgc;
nvidia-smi -rmc;
nvidia-smi -r;
nvidia-smi -i 0 -c 0;
but they didn’t help.
After tests in multiple games (Control; Hitman (2016)) and benchmarks (OCCT, Furmark) i noticed that my fps decreased in around 2.5 times, gpu clock in games is now at 950-1200mhz (instead of 1850+), TDP is now 100-120 watts (instead of around 200w).
nvidia-smi --query-gpu “power.limit” format=csv
says that power limit is set to 200w.
This problem stays at both Linux and Windows
How can I get back productivity of my GPU to default?
Here is my system:
Graphics card model: Gigabye eagle Nvidia geforce rtx 3060 ti oc lhr rev 2.0
GPU Bios version: 94.04.6B.00.F0
GPU driver version: game ready 566.36
Motherboard: Gigabyte x570 i aorus pro wifi
CPU: ryzen 7 5800x
PSU: 650 Watt Fractal Design Ion SFX Gold SFX12V-L Modular 80+ Gold
RAM: 32GB Kingston FURY Beast DDR-4 3600
OS: Arch linux: Linux kernel version: 6.12.4
Windows 11: 24h2
nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Tue Dec 17 21:32:26 2024
Driver Version : 565.77
CUDA Version : 12.7
Attached GPUs : 1
GPU 00000000:09:00.0
Product Name : NVIDIA GeForce RTX 3060 Ti
Product Brand : GeForce
Product Architecture : Ampere
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Enabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-4faf2fda-5089-1b45-2fda-1355a01100fe
Minor Number : 0
VBIOS Version : 94.04.6B.00.F0
MultiGPU Board : No
Board ID : 0x900
Board Part Number : N/A
GPU Part Number : 2489-202-A1
FRU Part Number : N/A
Platform Info
RACK Serial Number : N/A
Chassis Physical Slot Number : N/A
Compute Slot Index : N/A
Node Index : N/A
Peer Type : N/A
Module Id : 1
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : No
GPU Recovery Action : None
GSP Firmware Version : 565.77
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x09
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x248910DE
Bus Id : 00000000:09:00.0
Sub System Id : 0x405B1458
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 1050 KB/s
Rx Throughput : 399550 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 8192 MiB
Reserved : 328 MiB
Used : 625 MiB
Free : 7240 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 26 MiB
Free : 230 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 44 %
Memory : 10 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 33 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 93 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : 19.53 W
Current Power Limit : 200.00 W
Requested Power Limit : 200.00 W
Default Power Limit : 200.00 W
Min Power Limit : 100.00 W
Max Power Limit : 220.00 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 2160 MHz
SM : 2160 MHz
Memory : 7001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 687.500 mV
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
