WSL2 GPU-PV: CUDA throughput degrades over days; wsl --shutdown does not recover, restarting the NVIDIA device does
(microsoft/WSL の issue と NVIDIA Developer Forums「CUDA on Windows Subsystem for Linux」に出す用の英文。数字は 2026-09-21〜25 の実測)
Title: GPU-PV (dxgkrnl): CUDA workload slows ~1.7× over 3–4 days of host uptime with accumulating dxgvmb_send_sync_msg: wait_for_completion failed in dmesg; wsl --shutdown does not recover, pnputil /restart-device on the GPU does
Environment
- Windows 11 Home 10.0.26200.9457, host RAM 63.6 GB
- WSL 2.7.11.0, kernel 6.18.33.2-2 (
6.18.33.2-microsoft-standard-WSL2), WSLg 1.0.73.2, Direct3D 1.611.1-81528511, DXCore 10.0.26100.1 .wslconfig:memory=52GB,swap=16GB- NVIDIA GeForce RTX 5090 (32 GB), driver 610.88 (32.0.16.1088, 2026-07-22)
- Workload: ComfyUI 0.33 (PyTorch 2.13.0+cu130) running a video diffusion model (MiniMax H3), 100% CUDA, no Vulkan/GL. ~20–30 GB VRAM, ~44 GB guest RSS.
Symptom
The same fixed job (576×1344×158 frames, 3 sampling steps, i2v) measured with a per-node timer:
| host uptime | total | sampler node | video VAE decode | audio VAE decode |
| fresh (host reboot 09-21) | 33 s | 19.5 s | ~12 s | ~0.2 s |
| +4 days (09-25) | 52–55 s | 30–33 s | 12–15 s | 6–15 s |
- During the slow state the GPU is busy (98% util, 540 W) for only ~12 of the ~30 s the sampler node takes; the rest is the guest waiting on the host. Trivial kernels (audio VAE, <1 s of work) take 10+ s.
nvidia-smiitself becomes slow to respond. - GPU clocks/temps/throttle reasons are normal (2.9 GHz, 70 °C, no throttling). Guest swap in/out ≈ 0 during the job, PSI memory 0, CPU load 1.5.
- Windows System event log shows no nvlddmkm / DxgKrnl / Display errors during this period (only Hyper-V VmSwitch info events).
dmesg signature (guest)
Errors accumulate day by day (counts since VM boot on 09-22 03:28):
misc dxg: dxgk: dxgvmb_send_sync_msg: wait_for_completion failed: fffffe00 ×152
misc dxg: dxgk: process_completion_packet: did not find packet to complete ×152
misc dxg: dxgk: dxgkio_query_adapter_info: Ioctl failed: -512 / -2 ×63
| 09-22 (boot day) | 09-23 | 09-24 | 09-25 (until noon) |
| 31 | 0 | 185 | 175 |
In the healthy state the same job adds 0 errors; in the degraded state 4 runs add ~12. (~28 query_adapter_info errors appear at every VM boot and are not related.)
What does NOT recover it
- Restarting the CUDA process (ComfyUI)
wsl --shutdownand starting the distro again — the fresh VM is still at 52–55 s, and starts logging the same dxg errors within minutes (28 in 21 min)- Win+Ctrl+Shift+B (WDDM graphics stack restart)
- Disabling pinned host memory in the application
What DOES recover it (without a host reboot)
wsl --shutdown- Restart the GPU device:
pnputil /restart-device "PCI\VEN_10DE&DEV_2B85&..."(or Device Manager disable → enable) - Start the distro again
→ back to 34.0 / 34.1 / 34.2 s, audio VAE 0.2 s, 0 new dxg errors. A full host reboot also recovers it (09-21). Note: restarting the device while the VM is running pulls the GPU out from under the guest (nvidia-smi: GPU access blocked by the operating system, dxgvmb_send_create_process: create_process failed -75), so the VM must be shut down first.
Interpretation
The accumulated state lives on the host side of the GPU-PV path (nvlddmkm / dxgkrnl host), not in the guest kernel or the VM: a new VM inherits the slowness, and only re-initializing the WDDM device clears it. Looks related to microsoft/WSL#41682 (same dxgvmb_send_sync_msg timeouts, same WSL/kernel versions, Intel Arc) and to the RTX 5060 Ti + WSL2 nvlddmkm DPC-latency reports on the NVIDIA forums (369079, 370836).
Reproduction
Keep the host up and run CUDA video-generation jobs for 3–4 days (several hours of GPU time per day); measure the same job daily. I can provide: full dmesg, wsl --version, nvidia-smi -q, the per-node timing tool, and collect-wsl-logs output on request.
also posted:
