Hope you all had a great start to the New Year!
We are back here again to announce the release of the latest version of the preview driver, and this update includes many features that you have eagerly been asking for!
We are pleased to inform you that WSL2 WIP driver 465.42 is now available for download. CUDA 11.2 toolkit will be functional for WSL v2 with this release. The soul of this driver release are some performance improvements we have made. Please let us know below what you think!
Please register for the NVIDIA Developer Program and the Microsoft Windows Insider Program , to access the driver installers and documentation from the Downloads area on our CUDA on WSL webpage.
Our user guide and blog links below, contain valuable information to aid you to learn how CUDA works with WSL, including how to get started with running applications, and deep learning containers.
We encourage all of our developers to use our Forum for sharing their experience with the larger WSL community.
imkow
January 30, 2021, 1:16pm
3
Thanks very much. Finally got CUDA 11.2 support. Nevertheless, I find 465.42 causes MS Flight Simulator (2020) starts with black screen. This could be caused by WDDM 3.0 supported, not likely, though. Could anyone tell me where to report the problem? It’s not for this forum obviously.
Brightness controls no longer work on my device since updating to 465.42. Everything else seems to work fine, e.g. Cuda toolkit 11.2. I am on Windows build 21301 with an HP ZBook studio x360 G5. Any suggestions? (tried disabling and enabling device driver, and of course restarting).
Jecode
February 1, 2021, 9:10am
5
I installed this new driver 465.42, and when I’m trying to run nvidia-smi.exe in powershell, it crashes nvidia-smi.exe right away.
I thought that this could be some old driver issue, so I tried install driver again, but this time as a clean installation, didn’t work either.
Is there way to fallback on older version?
Edit: i9-9900k + 2080Ti
PS C:\Users\Jecode> nvidia-smi.exe
Mon Feb 1 10:45:09 2021
| NVIDIA-SMI 461.40 Driver Version: 461.40 CUDA Version: 11.2 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 GeForce RTX 208... WDDM | 00000000:01:00.0 On | N/A |
| 0% 51C P8 39W / 300W | 1089MiB / 11264MiB | 13% Default |
| | | N/A |
nvidia-docker does not work on this driver.
opened 05:15PM - 09 Feb 21 UTC
closed 10:04PM - 23 Jun 21 UTC
### 1. Issue or feature description
The title explains most of the issue, but … to give more context, my windows insider build is Build 21301.rs_prerelease.210123-1645
My nvidia drivers are updated to the latest as well on driver version 465.42:
| NVIDIA-SMI 460.27.04 Driver Version: 465.42 CUDA Version: 11.3 |
| | | MIG M. |
| 0 GeForce RTX 2060 Off | 00000000:0A:00.0 On | N/A |
| 57% 58C P0 114W / 350W | 3878MiB / 24576MiB | ERR! Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
I also have the latest Docker Desktop with WSL2 Integration for the GPU!
### 2. Steps to reproduce the issue
When I launch this, it works:
`docker run --rm --gpus all nvidia/cuda:11.0-cudnn8-devel-ubuntu18.04`
BUT, when I launch this:
`docker run --rm --gpus all nvidia/cuda:11.1.1-cudnn8-devel-ubuntu18.04`
I get this:
`docker: Error response from daemon: OCI runtime create failed: container_linux.go:370: starting container process caused: process_linux.go:459: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: requirement error: unsatisfied condition: cuda>=11.1, please update your driver to a newer version, or use an earlier cuda container: unknown.`
https://forums.developer.nvidia.com/t/wsl2-cuda-driver-465-42-not-working-with-nvidias-cuda-11-1-1-docker-containers/167662
### 3. Information to [attach](https://help.github.com/articles/file-attachments-on-issues-and-pull-requests/) (optional if deemed irrelevant)
- [ ] Some nvidia-container information: `nvidia-container-cli -k -d /dev/tty info`
- [ ] Kernel version from `uname -a`
- [ ] Any relevant kernel output lines from `dmesg`
- [ ] Driver information from `nvidia-smi -a`
- [ ] Docker version from `docker version`
- [ ] NVIDIA packages version from `dpkg -l '*nvidia*'` _or_ `rpm -qa '*nvidia*'`
- [ ] NVIDIA container library version from `nvidia-container-cli -V`
- [ ] NVIDIA container library logs (see [troubleshooting](https://github.com/NVIDIA/nvidia-docker/wiki/Troubleshooting))
- [ ] Docker command, image and tag used
```$ uname -a
Linux HOST-PC 5.4.72-microsoft-standard-WSL2 NVIDIA/nvidia-docker#1 SMP Wed Oct 28 23:40:43 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
root@HOST-PC:~# docker version
Client: Docker Engine - Community
Version: 20.10.3
API version: 1.41
Go version: go1.13.15
Git commit: 48d30b5
Built: Fri Jan 29 14:33:21 2021
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.3
API version: 1.41 (minimum version 1.12)
Git commit: 46229ca
Built: Fri Jan 29 14:31:32 2021
Experimental: false
containerd:
Version: 1.4.3
GitCommit: 269548fa27e0089a8b8278fc4fc781d7f65a939b
runc:
Version: 1.0.0-rc92
GitCommit: ff819c7e9184c13b7c2607fe6c30ae19403a7aff
docker-init:
Version: 0.19.0
GitCommit: de40ad0
==============NVSMI LOG==============
Timestamp : Tue Feb 9 13:57:41 2021
Driver Version : 465.42
CUDA Version : 11.3
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : GeForce RTX 2060 SUPER
Product Brand : GeForce RTX
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-c9d4e34c-cbf6-4dea-9f87-959d9eb94069
Minor Number : N/A
VBIOS Version : 90.06.44.40.20
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.02.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x00001F06
Bus Id : 00000000:01:00.0
Sub System Id : 0x86FC1043
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 16000 KB/s
Rx Throughput : 12000 KB/s
Fan Speed : 0 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 8192 MiB
Used : 1579 MiB
Free : 6613 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 7 %
Memory : 4 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 39 C
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
GPU Max Operating Temp : 89 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 30.89 W
Power Limit : 175.00 W
Default Power Limit : 175.00 W
Enforced Power Limit : 175.00 W
Min Power Limit : 105.00 W
Max Power Limit : 219.00 W
Clocks
Graphics : 68 MHz
SM : 68 MHz
Memory : 166 MHz
Video : 539 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2280 MHz
SM : 2280 MHz
Memory : 7001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1532
Type : C+G
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 2076
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.YourPhone_1.21011.127.0_x64__8wekyb3d8bbwe\YourPhone.exe
Process ID : 2936
Type : C+G
Name : C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
Process ID : 2964
Type : C+G
Process ID : 4824
Type : C+G
Process ID : 5196
Type : C+G
Name : C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe
Process ID : 5280
Type : C+G
Name : C:\Program Files\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
Process ID : 6680
Type : C+G
Process ID : 7536
Type : C+G
Process ID : 10860
Type : C+G
Process ID : 10968
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.SkypeApp_15.68.96.0_x86__kzf8qxf38zg5c\Skype\Skype.exe
Process ID : 12032
Type : C+G
Name : C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
Process ID : 12324
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.20122.11121.0_x64__8wekyb3d8bbwe\Video.UI.exe
Process ID : 13064
Type : C+G
Process ID : 15752
Type : C+G
Process ID : 15932
Type : C+G
Name : C:\Program Files\Google\Chrome\Application\chrome.exe
Process ID : 15984
Type : C+G
Process ID : 16808
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2020.20120.4004.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
Process ID : 17188
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.549981C3F5F10_2.2101.25001.0_x64__8wekyb3d8bbwe\Cortana.exe
Process ID : 18280
Type : C+G
Process ID : 19128
Type : C+G
Name : C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXE
Process ID : 21016
Type : C+G
Process ID : 22500
Type : C+G
Used GPU Memory : Not available in WDDM driver model ```
Hello all!
The title explains most of the issue, but to give more context, my windows insider build is Build 21301.rs_prerelease.210123-1645
| GPU Name Persistence-M| Bus…
ob13561
February 12, 2021, 9:29am
7
How do I roll back to 465.21 from 465.42? I do not have a roll back driver option in device manager. Trying to fix my issue of brightness controls no longer working.
eduard1
February 20, 2021, 9:23pm
8
I’ve installed this driver on Windows 10 pro preview (build 21318.1000) On Lenovo Legion 7 with GTX 2070 Super to try out WSL2 feature.
Here are the issues I’ve encountered:
immediately after install the brightness controls no longer work
after restart the laptop display goes black and no longer works (the external display on hdmi seems fine)
The only solution was to revert to the driver version provided by lenovo (457.20), but GPU on WSL2 no longer works. Any suggestions on what might go wrong?
Just installed 465.42 on build 21318.1000 using an RTX2080. Unfortunately I am encountering severe screen flickering in the top half of my screen after installing the driver. Rolling back resolves this issue.
İnstalling CUDA GEFORCE driver caused a black screen blinking on the top of my screen. Is there any other working driver available?
With this driver and WIP 21327.1000 my 2080ti does not shown in nvidia-smi anymore:
| NVIDIA-SMI 465.42 Driver Version: 465.42 CUDA Version: 11.3 |
| | | MIG M. |
Also i have an issue with previously woking container.
Is there a reason why CUDA drivers are currently unavailable when I navigate to https://developer.nvidia.com/cuda/wsl/download ?
jsf3rd
March 18, 2021, 1:24am
13
Message is changed!!
New developer drivers are planned to be made available this coming Monday 03/22/21, thanks for your patience.
Wow!
Any update on the drivers, now that it’s 03/22/21?
It’s March 23 already. I wonder in what part of the world it’s still 03/22.
raofr1
March 23, 2021, 7:26am
16
03/22。。。Any driver is ok. Where can I download it?
Anyone have the previous version of CUDA driver for wsl2? I need that, thanks for hlep.
siddok
March 23, 2021, 5:57pm
18
This is an incredible move: delete old driver and do not release a new one.
If somebody can share the previous version please do
Hi, I’m new here. Just wondering if this is normal for Nvidia, to delete any means of downloading previous drives
Maybe the old driver had a serious problem that they are now trying to fix. Still happy that I am not the only one waiting for the Download :-)!
Does anyone know what happens?
