Hello all!
The title explains most of the issue, but to give more context, my windows insider build is Build 21301.rs_prerelease.210123-1645
My nvidia drivers are updated to the latest as well on driver version 465.42:
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 460.27.04 Driver Version: 465.42 CUDA Version: 11.3 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 GeForce RTX 3090 Off | 00000000:0A:00.0 On | N/A | | 57% 58C P0 114W / 350W | 3878MiB / 24576MiB | ERR! Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+
I also have the latest Docker Desktop with WSL2 Integration for the GPU!
When I launch this, it works:
docker run --rm --gpus all nvidia/cuda:11.0-cudnn8-devel-ubuntu18.04
BUT, when I launch this:
docker run --rm --gpus all nvidia/cuda:11.1.1-cudnn8-devel-ubuntu18.04
I get this:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:370: starting container process caused: process_linux.go:459: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: requirement error: unsatisfied condition: cuda>=11.1, please update your driver to a newer version, or use an earlier cuda container: unknown.
I made sure my nvcc --version also prints this:
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Mon_Nov_30_19:08:53_PST_2020
Cuda compilation tools, release 11.2, V11.2.67
Build cuda_11.2.r11.2/compiler.29373293_0
Has anyone also been having the same issue? Here’s the reference link to the containers I’m using for Docker:
nvidia/cuda Tags - Docker Hub
